[postgis-users] upgrading from 1.4 to 1.5.1
Nick Bower nick at petangent.net
Mon Apr 19 15:11:55 PDT 2010
The docs are a bit rough in this area imo but I think it is assuming
postgis 1.5 is installed (to libdir/postgis-1.5).
Btw my experience is that it will also assume postgis 1.4 is installed
to libdir/postgis.  Confusingly when I ran 1.3 to 1.5 I found this and
that I needed to have both installed to upgrade.
On 20/04/2010, at 4:21 AM, P Kishor <punk.kish at gmail.com> wrote:
> Per the docs at
> <http://www.postgis.org/documentation/manual-1.5/ch02.html#upgrading>,
> I "should find several postgis_upgrade*.sql files." But, it doesn't
> say where I should find them. A little bit of poking around revealed
> the following files to be inside the postgis directory
> punkish at Lucknow ~/Projects/postgis-1.5.1$ll postgis
> -rw-r--r--  1 punkish  punkish  173460 Apr 19 12:51
> postgis_upgrade_13_to_15.sql
> -rw-r--r--  1 punkish  punkish  173221 Apr 19 12:51
> postgis_upgrade_14_to_15.sql
> -rw-r--r--  1 punkish  punkish  170268 Apr 19 12:51
> postgis_upgrade_15_minor.sql
> So, I suggest the documentation be corrected to "you should find
> several postgis_upgrade*.sql files in the 'postgis' folder."
> Then, I ran the following command, and got errors --
> punkish at Lucknow ~/Projects/postgis-1.5.1$psql -f
> postgis/postgis_upgrade_14_to_15.sql -d dbname
> BEGIN
> CREATE FUNCTION
>       postgis_major_version_check
> Scripts versions checked for upgrade: ok
> (1 row)
> DROP FUNCTION
> psql:postgis/postgis_upgrade_14_to_15.sql:49: ERROR:  could not access
> file "$libdir/postgis-1.5": No such file or directory
> psql:postgis/postgis_upgrade_14_to_15.sql:53: ERROR:  current
> transaction is aborted, commands ignored until end of transaction
> block
> and so on.
> Suggestions?
> Puneet Kishor
> postgis-users mailing list
