[postgis-users] Search Engine
    Bèrto ëd Sèra
    berto.d.sera at gmail.com
    Wed Aug  4 23:40:03 PDT 2010
+1 for triggers. It's always the best way to solve these situations, be it
GIS or not.
Bèrto
On 4 August 2010 11:55, uli mueller <uli.mueller at gmx.ch> wrote:
> Ricardo,
> Clearly, if you want to search across different tables you need a way to
> combine data in a common place. You should not do anything like search
> the tables one after the other and combine the results.
> Even if you merge all tables into one, you will need some explicit
> mechanism (trigger!) to keep your tsvector up to date.
> Using inheritance? I would not see inheritance as a real goodie with
> PostgreSQL. There are some serious caveats that may cause more problems
> than inheritance can solve. Check the last paragraph in the docs on
> inheritance
> (http://www.postgresql.org/docs/8.4/interactive/ddl-inherit.html).
> A system using triggers to build the tsvector is not so hard to
> maintain. Once you have written the triggers it simply runs and runs.
> Any time data in any relevant table changes, a trigger updates the
> tsvector, some key (gid or whatever) and maybe other data like bounding
> boxes in the one and only table that will be searched. Some challenge
> could arise, if it takes too long to rebuild your index on the tsvector.
> But normally this is not critical.
> We use the trigger approach for our search engine on
> http://mapmatters.org . The hardest thing there was and still is to
> optimize the way how data are combined and weighted for the tsvector (
> so how you feed the "to_tsvector" function).
> Uli
> Am 04.08.2010 00:33, schrieb Ricardo Bayley:
> > Hi fellows,
> > I am creating a search engine for my spatial data.
> > And I am thinking of the best approach.
> > My idea is to have a full text search (tsvector) coulmn for every table.
> > Instead of performing a search on every table, I have thought of a few
> > options
> > 1. "Merge" all tables into one, regardless of their geometry type.
> > 2. Use PostgreSQL goodies such as table Inheritance to split geometry
> > types. (not sure if it would be of any good)
> > 3. Create a table to store table oid, gid and full text search data of
> > every table in my system, and query this table instead. This should be
> > harder to maintain, since it should be done through triggers and rules.
> > Hope I explained it clearly.
> > By the way, at start I only have 20 tables, with not more than 500k rows
> > total. So it is not much, but this should grow considerably.
> > Do you guys have any thoughts on this ?
> > Looking foward to hearing from you.
> > Ricardo
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> geOps GeoInformatics
> www.geOps.de
> D-79098 Freiburg
Constitution du 24 juin 1793 - Article 35. - Quand le gouvernement viole les
droits du peuple, l'insurrection est, pour le peuple et pour chaque portion
du peuple, le plus sacré des droits et le plus indispensable des devoirs.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100805/048a7ab3/attachment.html>
