[postgis-users] QGIS requires
Andrea Peri aperi2007 at gmail.com
Wed Aug 18 12:08:19 PDT 2010
Using the plugin "RT SQL Layer" is possible to add to qgis a query sql .
It call directly posgres without use a memory provider, without save
temporary data on datafile and without creating temporary tables.
But again qgis need to have a field with unique integers.
I don't sure but perhaps to avoid this needed you can use the
"generate_series" to add a sequence number to your query sql.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100818/1598cb7e/attachment.html>
