[postgis-users] Loading spatial point from text file
Sairam Krishnamurthy kmsram420 at gmail.com
Mon Dec 6 08:43:02 PST 2010
All,
I have a test file that contains the data to the loaded to the spatial
table I have. The table structure is <lat,lon,data1,data2,spatialPoint>.
Sample data in the txt file : <-64.7647, -56.57647, 1234548, 1221312>.
So I want to load the table from this text file. I use the COPY query
below.
*COPY "table_name" (lat,lon,data1,data2) FROM 'FILE' DELIMITER ','*
But the problem is I am not able to update the spatialPoint using copy
query. So for now I am loading the lat,lon,data1,data2 fields and then
update the spatialPoint using a separate query similar to one below:
*UPDATE "table_name" SET "spatialPoint" =
ST_SetSRID(ST_MakePoint(lat,lon),4326) WHERE "spatialPoint" IS NULL*
My question is, is there a way to avoid the second query so that I can
also load the spatialPoint in the COPY query?
Also I initial dint want to have lat,lon in the table and have only the
spatialPoint field. Because of the above problem I was forced to have
lat,lon fields in the table. Someway to achieve this will help me a lot.
Thanks,
+1 612 859 8161
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101206/a8358955/attachment.html>
