[postgis-users] postgis from ubuntu to suse
pcreso at pcreso.com pcreso at pcreso.com
Tue Dec 7 12:18:27 PST 2010
Hi Vinicius,
If SuSE created a Postgis enabled template, you could use that as the basis for your new database, so it will already have Postgis installed.
Otherwise use the usual commands to install Postgis in a Postgres database:
createlang plpgsql <new db>  (not needed with Postgres v9.0+)
psql -d <new db> -f <path to>/postgis.sql
psql -d <new db> -f <path to>/spatial_reference_sys.sql
You'll need to find where SuSE has put the last two files, if you have "locate" installed, then
"locate postgis.sql" will tell you where, or you can use "find"...
According to
http://wiki.openstreetmap.org/wiki/Mapnik/PostGIS#For_Opensuse_11_2
the path is  /usr/share/postgresql/contrib/
Cheers,
  Brent Wood
--- On Wed, 12/8/10, Vinicius <vinicius647 at gmail.com> wrote:
Subject: Re: [postgis-users] postgis from ubuntu to suse
To: pcreso at pcreso.com
Cc: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Wednesday, December 8, 2010, 4:58 AM
  Hi..
    I created the database manually, but how do I install postgis into
    this database ?
    I´ve used Software Management to install postgresql and postgis, but
    when I create a new database it´s completelly empty.
    tks..
    On 06/12/2010 20:00, pcreso at pcreso.com wrote:
            Which version of
              PostGIS is on each box?
              One q'n'd approach which works for me is to create the
              target db manually, install Postgis into this manually,
              then use pg_dump <src db params> | psql <target
              db params>
              Brent Wood
              --- On Tue, 12/7/10, Vinicius <vinicius647 at gmail.com>
              wrote:
                Subject: [postgis-users] postgis from ubuntu to suse
                To: postgis-users at postgis.refractions.net
                Date: Tuesday, December 7, 2010, 8:27 AM
                Hi people..
                  I´ve had some problems to restore a database backup
                  from postgresql 8.3 on Ubuntu to postgresql 8.4 on
                  OpenSuse 11.3. I have many tables and indexes using
                  postgis, but when I try to restore them on OpenSuse
                  many errors about libs occurs.
                  How Can I solve this problem, it is possible ?
                  tks...
                  postgis-users mailing list
                  http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101207/65b2ae75/attachment.html>
