[postgis-users] Upgrade Postgres & Postgis
Kevin Neufeld kneufeld.ca at gmail.com
Wed Dec 8 08:35:14 PST 2010
Hi Graeme,
Can you isolate the problem?  Find a small geometry that is in your
original data but not in your new database and place it in it's own
table.  Then try to dump / restore the single table.  If possible post
your problematic geometry here.
Maybe it's a particularly bad / invalid geometry that the new parser is
having problems with.
-- Kevin
On 12/8/2010 4:27 AM, Graeme Gould wrote:
> Hi Ralf
> Thanks for the response.  Think I should have been clearer - it does not seem to be the geometry column table that is the issue, but the geometry field in the data table that is occasionally missing data.  It is in the original table in version 8.2 but is not picked up in the backup or restore process.
> Graeme
