[postgis-users] Determining clusters of points
Kevin Neufeld kneufeld.ca at gmail.com
Wed Dec 8 18:07:49 PST 2010
On 12/8/2010 3:58 PM, Sébastien Lorion wrote:
> ... So to be clear, even tho the points "interact" with a range of 40,
> they are not clustered together with the function you sent.
Um ... no. Sorry, there is miscommunication happening here.
The recursive script I posted is checking if two points are within 80
units of each other.   If you wanted to view the result as buffered
areas, you would use a radius of 40, not 80.
So, if you wanted to have clusters where points are within 40 units of
each other, you would view this using a radius of 20.
Make sense?
-- Kevin
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101208/b806343c/attachment.png>
