[postgis-users] Can anyone interpret this error? ERROR: current transaction
Paul Ramsey
pramsey at opengeo.org
Sat Dec 11 15:45:39 PST 2010
Yes, apparently there's a binary compatibility issues between the
version of C++ the .so was compiled against and the version you have.
What distro/version are you installing into? (BTW, we should be able
to largely avoid these with the upcoming Ubuntu packages for the
Suite.)
Paul
On Sat, Dec 11, 2010 at 12:22 PM, Robert Buckley
<robertdbuckley at yahoo.com> wrote:
> hi,
> I outputted the error into a file and found the beginning of the problem..
> psql:/home/geoserver/opengeosuite-2.3.0/pgsql/share/contrib/postgis-1.5/postgis.sql:59:
> ERROR: could not load library
> "/home/geoserver/opengeosuite-2.3.0/pgsql/lib/postgis-1.5.so":
> /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by
> /home/geoserver/opengeosuite-2.3.0/pgsql/scripts/../../pgsql/lib/libgeos-3.2.3.so)
> Any logical reason why this couldn´t load?
> yours,
> Robert Buckley
> postgis-users mailing list
