[postgis-users] Shifting linestrings left
Ben Madin lists at remoteinformation.com.au
Wed Dec 22 19:56:49 PST 2010
Thanks Brent,
Happy Christmas / New Year to you as well!
On 23/12/2010, at 2:07 PM, pcreso at pcreso.com wrote:
> ST_Translate() is the simplest, but if your lines are horizontal you may want a Y shift as well?
> http://postgis.refractions.net/documentation/manual-svn/ST_Translate.html
Lines are roads, so they go every which way.
> Having done this, I suggest you also use ST_reverse() to reflect the direction is now going the other way (unless it already is :-)
> http://postgis.refractions.net/documentation/manual-svn/ST_Reverse.html
> For more complex shifting of features, probably overkill in your case, see
> http://postgis.refractions.net/documentation/manual-svn/ST_Affine.html
This might be what I am after, but I was thinking of somehow translating each segment parallel to it's current alignment and then rejoining with a nice smooth curve... kind of like a 1-sided buffer.
cheers
Ben
> --- On Thu, 12/23/10, Ben Madin <lists at remoteinformation.com.au> wrote:
> From: Ben Madin <lists at remoteinformation.com.au>
> Subject: [postgis-users] Shifting linestrings left
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Thursday, December 23, 2010, 3:13 PM
> G'day all,
> I have a problem where I am trying to show the route of livestock movements, but I am loosing information when the travel along the same road in different directions (ie in some cases they travel from a saleyard to a feedlot, then back to the saleyard after a period). The roads they travel along are single linestrings.
> Is there a way to 'shift' the linestring to the left - after all, that would be sensible side of the road to drive on...
> cheers
> Ben
> postgis-users mailing list
