[postgis-users] Shifting linestrings left
Simon Greener simon at spatialdbadvisor.com
Wed Dec 22 22:03:39 PST 2010
Ben,
See Regina Obe's upgis_lineshift
http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctions
I have a PostGIS version, without the curves, of this one:
http://www.spatialdbadvisor.com/oracle_spatial_tips_tricks/97/implementing-a-move-parallel-function-for-sdo_geometry-linestring-data-in-oracle
If you want the code, email me privately as I have not yet blogged on it.
Simon
On Thu, 23 Dec 2010 14:56:49 +1100, Ben Madin <lists at remoteinformation.com.au> wrote:
> Thanks Brent,
> Happy Christmas / New Year to you as well!
> On 23/12/2010, at 2:07 PM, pcreso at pcreso.com wrote:
>> ST_Translate() is the simplest, but if your lines are horizontal you may want a Y shift as well?
>> http://postgis.refractions.net/documentation/manual-svn/ST_Translate.html
> Lines are roads, so they go every which way.
>> Having done this, I suggest you also use ST_reverse() to reflect the direction is now going the other way (unless it already is :-)
>> http://postgis.refractions.net/documentation/manual-svn/ST_Reverse.html
>> For more complex shifting of features, probably overkill in your case, see
>> http://postgis.refractions.net/documentation/manual-svn/ST_Affine.html
> This might be what I am after, but I was thinking of somehow translating each segment parallel to it's current alignment and then rejoining with a nice smooth curve... kind of like a 1-sided buffer.
> cheers
> Ben
>> --- On Thu, 12/23/10, Ben Madin <lists at remoteinformation.com.au> wrote:
>> From: Ben Madin <lists at remoteinformation.com.au>
>> Subject: [postgis-users] Shifting linestrings left
>> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>> Date: Thursday, December 23, 2010, 3:13 PM
>> G'day all,
>> I have a problem where I am trying to show the route of livestock movements, but I am loosing information when the travel along the same road in different directions (ie in some cases they travel from a saleyard to a feedlot, then back to the saleyard after a period). The roads they travel along are single linestrings.
>> Is there a way to 'shift' the linestring to the left - after all, that would be sensible side of the road to drive on...
>> cheers
>> Ben
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
   Email: simon at spatialdbadvisor.com
   Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
