[postgis-users] Shifting linestrings left
Ben Madin lists at remoteinformation.com.au
Thu Dec 23 14:53:43 PST 2010
G'day Sean,
On 24/12/2010, at 2:07 AM, Sean wrote:
> Is this just a visualization issue?  You could store copies of the the
> road line with attribute data indicating direction or have a separate
> table with foreign keys to the geography and the direction data.
> Then, you just symbolize differently based on the attributes.  Offset
> the symbology not the geometry.  This is more correct, it preserves
> the information about the actual road on which they travel.  Showing
> direction of travel is strictly a symbology issue.
It's a mix of both - initially, it was a geometry issue - I have linestrings for roads, and for some I have information that suggests that they are dual carriageway, and I was wondering if we could approximate the dual carriageway by shifting the original geometry a little bit to the left going each way.
Then I realised I had better things to do, so I moved on, but now I have a need to show routes going both ways, but using pgRouting they (unsurprisingly) following the same lines, and I wanted to show it. Using QGIS I offset the symbology, but it doesn't actually seem to works how I wanted (which is nicely described by Simon's post), but rather looks like :
Name: Screen shot 2010-12-24 at 9.30.19 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101224/1212b3f1/attachment.png>
cheers (and Happy Christmas etc)
Ben
