[postgis-users] Polygon from point query
pcreso at pcreso.com pcreso at pcreso.com
Tue Dec 28 12:03:28 PST 2010
You need to have your points already in a table, then you can run a single query to identify the county each lies within.
SELECT p.point, c.county_nam
FROM county c,
             points p
WHERE  ST_Within(p.the_geom, c.the_geom);
You can also wrap this in an update statement to have a column in the point table with the id of the county to implement a foreign key to join the two tables on.
HTH,
  Brent Wood
--- On Wed, 12/29/10, Poynter, David <POYNTER at adeq.state.ar.us> wrote:
Subject: [postgis-users] Polygon from point query
To: "postgis-users" <postgis-users at postgis.refractions.net>
Date: Wednesday, December 29, 2010, 8:49 AM
This is probably an easy one, but being a PostGIS newb I've
been spinning my wheels and haven't the google fu to locate an answer, so here
goes...
I have a table of counties from the state (county) and I'm
creating a point to insert in another table and I would like to find the county
the point falls in.
I think I should be able to do it in one query rather than
looping thru county by county, but I can't seem to put it together.
SELECT county_nam FROM county WHERE ?
I've been looking at ST_Within() and think the answer lies
with it somehow, thanks for any clues...
-----Inline Attachment Follows-----
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101228/3262b54b/attachment.html>
