[postgis-users] Split a polygon to N linestrings (Solved)
Simon Greener simon at spatialdbadvisor.com
Tue Feb 2 01:56:38 PST 2010
Nicolas,
A more general solution that handles linestrings, multilinestrings etc via the use of a
function (which doesn't return a geometry rather a record of coordinates) can be
found here: http://www.spatialdbadvisor.com/postgis_tips_tricks/128/exploding-a-linestring-or-polygon-into-individual-vectors-in-postgis/
Simon
On Tue, 02 Feb 2010 18:56:13 +1100, Nicolas Gillet - MARKET-IP <nicolas.gillet at market-ip.com> wrote:
> Hello Kevin,
> Thank you a lot for this perfectly clear query !
> Nicolas
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Kevin
> Neufeld
> Envoyé : vendredi 29 janvier 2010 17:44
> À : PostGIS Users Discussion
> Objet : Re: [postgis-users] Split a polygon to N linestrings
> CREATE TEMP TABLE mypolygontable AS
> SELECT
>    'MULTIPOLYGON(((0 0, 0 4, 4 4, 4 0, 0 0),
>                   (1 1, 1 2, 2 2, 2 1, 1 1)),
>                  ((5 5, 5 6, 6 6, 6 5, 5 5))
>                 )'::geometry geom;
> -- make line segments from every startpoint and endpoint
> SELECT ST_AsText( ST_MakeLine(sp,ep) )
> FROM
>    -- extract the endpoints for every 2-point line segment for each
> linestring
>    (SELECT
>       ST_PointN(geom, generate_series(1, ST_NPoints(geom)-1)) as sp,
>       ST_PointN(geom, generate_series(2, ST_NPoints(geom)  )) as ep
>     FROM
>        -- extract the individual linestrings
>       (SELECT (ST_Dump(ST_Boundary(geom))).geom
>        FROM mypolygontable
>        ) AS linestrings
>     ) AS segments;
>        st_astext
>   LINESTRING(0 0,0 4)
>   LINESTRING(0 4,4 4)
>   LINESTRING(4 4,4 0)
>   LINESTRING(4 0,0 0)
>   LINESTRING(1 1,1 2)
>   LINESTRING(1 2,2 2)
>   LINESTRING(2 2,2 1)
>   LINESTRING(2 1,1 1)
>   LINESTRING(5 5,5 6)
>   LINESTRING(5 6,6 6)
>   LINESTRING(6 6,6 5)
>   LINESTRING(6 5,5 5)
> (12 rows)
> Cheers,
> Kevin
> On 1/29/2010 5:16 AM, Nicolas Gillet - MARKET-IP wrote:
>> Hello,
>> I am looking for some tips to split a polygon to its simplest linestrings.
>> An example worth better than words :
>> POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))
>> Would become :
>> MULTINLINESTRING((0 0, 0 1), (0 1, 1 1), (1 1, 1 0), (1 0, 0 0))
>> Every single linestring has to have two and only two points.
>> Is there a way to do this with the existing postgis functions ?
>> I found several ways to turn a polygon to a (multi)linestring but not to
>> split it then into shortest linestrings.
>> Thanks for any input.
>> Nicolas
>> Gillet
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
   Email: simon at spatialdbadvisor.com
   Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
