[postgis-users] digit problem about sql file.
ibrahim saricicek ibrahimsaricicek at gmail.com
Wed Feb 3 23:46:32 PST 2010
Hi;
use round function
SELECT round(4.1255545487878546, 4);
result---> 4.1256
Regards...
On Thu, Feb 4, 2010 at 9:40 AM, Hyung Joo Lee <procarrie at imrc.kist.re.kr>wrote:
> Hi all.
> I have a question about the decimal of shapefile that was created in
> Arcgis.
> The file I have defined the coordinates of the coordinate system like
> (56.631 55.612)
> That file was put in the DB using shp2pgsql( ---# shp2pgsql -a -w -S -I
> ###.shp table_name > ###.sql).
> And then I checked the sql file. But the point coordinates that comes a lot
> more than 3-digit  like 56.6313000004739 55.6119999999646
> I want to come out only 3-digit, so how can I do?
> What option should I use?
> I'll wait for the users a clear answer.
> Best regards and thanks in advance.
> Kevin.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100204/de81140a/attachment.html>
