[postgis-users] Union a very big Multipolygon table with self intersections
ibrahim saricicek ibrahimsaricicek at gmail.com
Fri Feb 5 00:44:51 PST 2010
Hi;
create a new geometry column
use update table set new_column=st_buffer(the_geom,0). IsValid will return
true. Then try the union operation..
IBO..
On Fri, Feb 5, 2010 at 12:46 AM, Javier de la Torre
<jatorre at vizzuality.com>wrote:
> Hi all,
> I have a table with a MULTIPOLYGON field with around 100k records. Some of
> these records, 2K have self intersections and other problems that make
> ST_IsValid return false. The polygons overlap a lot and I wanted to generate
> another table that will be the union of all polygons.
> The table looks like
> id, the_geom
> What would be the best way to union all of the geometries into a new table
> where there is only POLYGONS that do not overlap?
> Thanks in advance.
> Javier.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100205/992d6178/attachment.html>
