[postgis-users] I want to write "cluster by" instead of "group by" on geospatial point data, should I write the code at postgresql or postgis ?
Kevin Neufeld kneufeld at refractions.net
Fri Feb 5 08:51:56 PST 2010
I'm not sure I follow.  Can you explain what exactly you want to do?
The following query will collect points into clusters (multipoints), clustered on a 100x100 grid.
-- generate a sample random point dataset
CREATE TABLE points AS
SELECT ST_MakePoint(random()*1000, random()*1000) AS geom
FROM generate_series(1, 100000);
-- create point clusters
SELECT st_collect(geom)
FROM points
GROUP BY
   round(st_x(geom)/100)*100,
   round(st_y(geom)/100)*100;
Kevin
> data,should I write the code at postgresql or postgis ?
> thanks
> peng
> postgis-users mailing list
