[postgis-users] Fwd: re:I want to write "cluster by" instead of "group by" on geospatial point
sunpeng bluevaley at gmail.com
Mon Feb 8 15:18:19 PST 2010
hi,Kevin,thanks for your help.
Now, I'll explain my initial motivation.
Suppose we have a table with:
create table houses  (
   NAME              VARCHAR(128)                     not null,
SELECT AddGeometryColumn('houses', 'location', 4214, 'POINT', 2);
if we want to do clustering(in data mining environment) the houses on
location, that is, clustering those house near as a cluster(or a group), and
then calculate each cluster's shape, we can not use the following sql:
select ST_Boundary(*)
from houses
group by location
I would like to extend the postgresql or postgis to support the following
sql:
from houses
clustering by location
in which the following steps are considered:
1. cluster the houses into several goups
2. calculate each goup's shape
I know the second step is usually related to aggregation functions like
sum,count,and so on which i don't care too much now. All what I want to do
is to add this sql semantics into postgresql or postgis and then add a
clustering algorithm like dbscan in the executor in postgresql(or postgis?).
How could I do? Any detailed steps?Like I should modify kwlist.h to support
"CLUSTERING" keyword, and the following steps?
Thanks!
peng
we all know
I'm not sure I follow.  Can you explain what exactly you want to do?
The following query will collect points into clusters (multipoints),
clustered on a 100x100 grid.
-- generate a sample random point dataset
CREATE TABLE points AS
SELECT ST_MakePoint(random()*1000, random()*1000) AS geom
FROM generate_series(1, 100000);
-- create point clusters
SELECT st_collect(geom)
FROM points
GROUP BY
  round(st_x(geom)/100)*100,
  round(st_y(geom)/100)*100;
Kevin
> data,should I write the code at postgresql or postgis ?
> thanks
> peng
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100208/486706c4/attachment.html>
