[postgis-users] Finding a TopologyException
Ben Madin lists at remoteinformation.com.au
Sun Feb 14 23:51:40 PST 2010
G'day all,
I have a topology exception with a file I clean up with GRASS and exported back into PostGIS, which I discovered when I tried to merge provinces into countries:
CREATE TABLE new_country AS
	SELECT country::varchar(3), st_union(the_geom) as the_geom
	FROM new_prov
	GROUP BY country;
NOTICE:  TopologyException: found non-noded intersection between LINESTRING (-0.204257 0.999226, -0.204257 0.99858) and LINESTRING (-0.204257 0.995743, -0.204257 0.999226) at -0.204257 0.999226
There is obviously information here on where the problem lies, but my entire project is in Lat / Long (EPSG:4326) in South East Asia, so I'm guessing this is not (nor is it on a unit square)
So :
How does the coordinates returned by the error relate to my geometry? or What do they mean? Can I use this information to find the problem part of the geometry.
(as an aside, changing the query to st_union(st_buffer(the_geom,0)) let it through (and it works as I wanted)
cheers
Ben
