[postgis-users] Excel to Postgres
Stefan Keller sfkeller at gmail.com
Mon Feb 15 15:26:27 PST 2010
Assuming you have Windows you could either use ODBC and make a system
DSN entry :
> c:\windows\system32\odbcconf /a CONFIGSYSDSN "Microsoft Excel Driver (*.xls)" "DSN=test|DBQ=c:\test.xls|DefaultDir=C:|Description=Test"
or use Visual Basic as a macro in a master Excel
or use Java and http://poi.apache.org/ API for Microsoft documents.
-S.
2010/2/15  <Steve.Toutant at inspq.qc.ca>:
> Hi,
> Every day I receive an Excel file containing lat long coordinates. I need to
> import it to postgis.
> Currently, I save the Excel file in CSV format and I use ogr2ogr to import
> the contents into postgis. I would like to avoid human intervention.
> I tried unsuccessfully  to define an ODBC link on the Excel file and use
> ogr2ogr with odbc to import it to postgres/postgis.
> I got this error
> [Microsoft][ODBC Excel Driver] External table is not in the expected format
> Here is the command I sent
> ogr2ogr -f "PostgreSQL" PG:"host=xxx user=xxx password=xxx dbname=geo"
> "ODBC:odbc_urg,test" -nln "testODBCxls" -overwrite
> where test is the sheet name inside the excel file
> Anyone has a better idea on how to programmatically import excel data into
> postgis?
> thanks
> Steve
> postgis-users mailing list
