[postgis-users] make check has 2 failures
Andy Dale andy.dale at gmail.com
Tue Feb 16 04:50:15 PST 2010
I have compiled postgis 1.3.6 on Fedora 11 (Using Geos 3.2.0, and Proj
4.7.1), on running the "make check" tests for postgis I am currently seeing
2 failures:
f11_mapserver/postgis-1.3.6 > make check
make -C regress test
make[1]: Entering directory `/home/oper/f11_mapserver/postgis-1.3.6/regress'
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_27112
 PostgreSQL 8.3.8 on i386-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.4.1
20090725 (Red Hat 4.4.1-2)
 Postgis 1.3.6 - 2010-02-16 12:30:40
   GEOS: 3.2.0-CAPI-1.6.0
   PROJ: Rel. 4.7.1, 23 September 2009
Running tests
 loader/Point.............. ok
 loader/PointM.............. ok
 loader/PointZ.............. ok
 loader/MultiPoint.............. ok
 loader/MultiPointM.............. ok
 loader/MultiPointZ.............. ok
 loader/Arc.............. ok
 loader/ArcM.............. ok
 loader/ArcZ.......... ok
 loader/Polygon.............. ok
 loader/PolygonM.............. ok
 loader/PolygonZ.............. ok
 regress. ok
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. o
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. ok
 sql-mm-curvepoly. ok
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. ok
 geojson. ok
 regress_ogc. failed (diff expected obtained:
/tmp/pgis_reg_27112/test_35_diff)
 regress_bdpoly. ok
 regress_ogc_cover. ok
 regress_ogc_prep. ok
 regress_proj. ok
 kml. failed (diff expected obtained: /tmp/pgis_reg_27112/test_40_diff)
Run tests: 40
Failed: 2
make[1]: Leaving directory `/home/oper/f11_mapserver/postgis-1.3.6/regress'
The first error seems to be that the error message has changed when a
LinearRing has 3 points ??:
75c75
< NOTICE:  IllegalArgumentException: Number of points must be 0 or >3
> NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing
found 3 - must be 0 or >= 4
The second error is:
20c20
<Point><coordinates>-73.1978481045547,6.76797715816346</coordinates></Point>
<Point><coordinates>-73.1978481045547,6.76797715816347</coordinates></Point>
40c40
Is it OK to assume that these 2 errors are not serious ??
Thanks,
Andy
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100216/c4a9943f/attachment.html>
