[postgis-users] make check has 2 failures
Paul Ramsey pramsey at cleverelephant.ca
Tue Feb 16 08:17:13 PST 2010
Those are both "safe" regressions. The first one is odd though. I'd
run 'select postgis_full_version()' on that database to see if you
perhaps have linked to an old .so by mistake.
p
On Tue, Feb 16, 2010 at 4:50 AM, Andy Dale <andy.dale at gmail.com> wrote:
> Hi,
> I have compiled postgis 1.3.6 on Fedora 11 (Using Geos 3.2.0, and Proj
> 4.7.1), on running the "make check" tests for postgis I am currently seeing
> 2 failures:
> f11_mapserver/postgis-1.3.6 > make check
> make -C regress test
> make[1]: Entering directory `/home/oper/f11_mapserver/postgis-1.3.6/regress'
> Creating spatial db postgis_reg
> TMPDIR is /tmp/pgis_reg_27112
>  PostgreSQL 8.3.8 on i386-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.4.1
> 20090725 (Red Hat 4.4.1-2)
>  Postgis 1.3.6 - 2010-02-16 12:30:40
>    GEOS: 3.2.0-CAPI-1.6.0
>    PROJ: Rel. 4.7.1, 23 September 2009
> Running tests
>  loader/Point.............. ok
>  loader/PointM.............. ok
>  loader/PointZ.............. ok
>  loader/MultiPoint.............. ok
>  loader/MultiPointM.............. ok
>  loader/MultiPointZ.............. ok
>  loader/Arc.............. ok
>  loader/ArcM.............. ok
>  loader/ArcZ.......... ok
>  loader/Polygon.............. ok
>  loader/PolygonM.............. ok
>  loader/PolygonZ.............. ok
>  regress. ok
>  regress_index. ok
>  regress_index_nulls. ok
>  lwgeom_regress. ok
>  regress_lrs. ok
>  removepoint. o
>  setpoint. ok
>  simplify. ok
>  snaptogrid. ok
>  affine. ok
>  wkt. ok
>  measures. ok
>  long_xact. ok
>  ctors. ok
>  sql-mm-serialize. ok
>  sql-mm-circularstring. ok
>  sql-mm-compoundcurve. ok
>  sql-mm-curvepoly. ok
>  sql-mm-general. ok
>  sql-mm-multicurve. ok
>  sql-mm-multisurface. ok
>  geojson. ok
>  regress_ogc. failed (diff expected obtained:
> /tmp/pgis_reg_27112/test_35_diff)
>  regress_bdpoly. ok
>  regress_ogc_cover. ok
>  regress_ogc_prep. ok
>  regress_proj. ok
>  kml. failed (diff expected obtained: /tmp/pgis_reg_27112/test_40_diff)
> Run tests: 40
> Failed: 2
> make[1]: Leaving directory `/home/oper/f11_mapserver/postgis-1.3.6/regress'
> The first error seems to be that the error message has changed when a
> LinearRing has 3 points ??:
> 75c75
> < NOTICE:  IllegalArgumentException: Number of points must be 0 or >3
>> NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing
>> found 3 - must be 0 or >= 4
> The second error is:
> 20c20
> <Point><coordinates>-73.1978481045547,6.76797715816346</coordinates></Point>
>> <Point><coordinates>-73.1978481045547,6.76797715816347</coordinates></Point>
> 40c40
> Is it OK to assume that these 2 errors are not serious ??
> Thanks,
> Andy
> postgis-users mailing list
