[postgis-users] Postgis 1.3.7 wit PostgreSQL 8.4. (64bit) on OpenSolaris
Andreas Luka andreas at luka-online.de
Tue Feb 23 10:20:36 PST 2010
I compiled and installed geos-3.2.0 and proj-4.7.0 successfully with the
following options
CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" FFLAGS="-m64"
LDFLAGS="-L/usr/sfw/lib/amd64/" ./configure
make, make install, make check are also okay, files are installed in
/usr/local
ls /usr/local -al
drwxr-xr-x  2 root root        16 2010-02-24 00:43 .
drwxr-xr-x  6 root other        6 2010-02-24 00:35 ..
-rw-r--r--  1 root root    296214 2010-02-24 00:35 libgeos_c.a
-rwxr-xr-x+ 1 root root      1020 2010-02-24 00:35 libgeos_c.la
lrwxrwxrwx  1 root root        18 2010-02-24 00:35 libgeos_c.so ->
libgeos_c.so.1.6.0
lrwxrwxrwx  1 root root        18 2010-02-24 00:35 libgeos_c.so.1 ->
libgeos_c.so.1.6.0
-rwxr-xr-x+ 1 root root    215312 2010-02-24 00:35 libgeos_c.so.1.6.0
-rwxr-xr-x+ 1 root root   4777808 2010-02-24 00:35 libgeos-3.2.0.so
-rw-r--r--  1 root root  13625096 2010-02-24 00:35 libgeos.a
-rwxr-xr-x+ 1 root root       988 2010-02-24 00:35 libgeos.la
lrwxrwxrwx  1 root root        16 2010-02-24 00:35 libgeos.so ->
libgeos-3.2.0.so
-rw-r--r--  1 root root    751590 2010-02-24 00:43 libproj.a
-rwxr-xr-x+ 1 root root       841 2010-02-24 00:43 libproj.la
lrwxrwxrwx  1 root root        16 2010-02-24 00:43 libproj.so ->
libproj.so.0.6.6
lrwxrwxrwx  1 root root        16 2010-02-24 00:43 libproj.so.0 ->
libproj.so.0.6.6
-rwxr-xr-x+ 1 root root    440672 2010-02-24 00:43 libproj.so.0.6.6
I compiled postgis with the following options
CC="gcc -m64" CXX="g++" FFLAGS="-m64" LDFLAGS="-L/usr/sfw/lib/amd64/"
./configure --with-pgsql='/usr/postgres/8.4/bin/amd64/pg_config'
--with-geos='/usr/local/bin/geos-config' --with-proj='/usr/local'
--with-proj-libdir='/usr/local/lib'
make and make install are okay
ls -al /usr/postgres/8.4/lib/amd64/liblwgeo*
lrwxrwxrwx 1 root root     16 2010-02-24 00:45
/usr/postgres/8.4/lib/amd64/liblwgeom.so -> liblwgeom.so.1.3
/usr/postgres/8.4/lib/amd64/liblwgeom.so.1 -> liblwgeom.so.1.3
-rwxr-xr-x 1 root root 980520 2010-02-24 00:45
/usr/postgres/8.4/lib/amd64/liblwgeom.so.1.3
echo $LD_LIBRARY_PATH
/usr/local/lib
seems okay, restart of the database
but I still getting the following error when I run the sql query for
lwpostgis.sql:
HINWEIS:  Typ »histogram2d« ist noch nicht definiert
DETAIL:  Hüllentypdefinition wird erzeugt.
FEHLER:  konnte Bibliothek »/usr/postgres/8.4/lib/amd64/liblwgeom.so«
nicht laden: ld.so.1: postgres: fatal: libgeos_c.so.1: open failed: No
such file or directory
********** Fehler **********
FEHLER: konnte Bibliothek »/usr/postgres/8.4/lib/amd64/liblwgeom.so« nicht
laden: ld.so.1: postgres: fatal: libgeos_c.so.1: open failed: No such file
or directory
SQL Status:58P01
Any suggestion?
