[postgis-users] TIGER geocoder with Census 2009 shapefiles
Paragon Corporation lr at pcorp.us
Fri Feb 26 20:52:03 PST 2010
David,
As a matter of fact we've been working on that for chapter 10 of our
upcoming book and think we have it all working.  As a part of the example
generation process for our chapter 10, we had to come up with a way to load
the tables that works on both windows and Linux.  Unfortunately we haven't
had a chance to test the Linux loading approach, but is pretty much a
parallel of the windows approach.
To do so we started out with Steve's code, added some additional skeleton
tables and a database function that generates a command line script for the
respective OS.  Hopefully it all makes sense from the readme file we have
packaged.
We also changed one of the functions because there was an error in it and
revised slightly to work with Tiger 2009 data.  You can dowload our slightly
hacked version of Steve's code from our chapter 10 page.
Steve -- if you are listening we are hoping to remerge your version with our
loader part and bring back into the PostGIS distribution as part of PostGIS
1.5.1 or 2.0 release.
http://www.postgis.us/chapter_10
Leo and Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dave
Fuhry
Sent: Friday, February 26, 2010 3:04 PM
To: PostGIS Users Discussion
Subject: [postgis-users] TIGER geocoder with Census 2009 shapefiles
I'm trying to set up the TIGER geocoder from
http://www.snowman.net/git/tiger_geocoder/ which is new and aims to work
with the new TIGER shapefiles.  I'm trying with the 2009 shapefiles from
www2.census.gov/geo/tiger/TIGER2009/.
I'm not sure how to create the roads_local table (derived closely from
completechain in the old version).  A join between edges and addr?
Wondering if anyone can offer any direction.  A relevant ticket is
http://trac.osgeo.org/postgis/ticket/135.  The out-of-date file which used
to create the roads_local table is tables/roads_local.sql, in the above
repository.
-Dave
                                       Table "tiger.edges"
   Column   |          Type          |                         Modifiers
 gid        | integer                | not null default
nextval('public.edges_gid_seq'::regclass)
 statefp    | character varying(2)   |
 countyfp   | character varying(3)   |
 tlid       | bigint                 |
 tfidl      | bigint                 |
 tfidr      | bigint                 |
 mtfcc      | character varying(5)   |
 fullname   | character varying(100) |
 smid       | character varying(22)  |
 lfromadd   | character varying(12)  |
 ltoadd     | character varying(12)  |
 rfromadd   | character varying(12)  |
 rtoadd     | character varying(12)  |
 zipl       | character varying(5)   |
 zipr       | character varying(5)   |
 featcat    | character varying(1)   |
 hydroflg   | character varying(1)   |
 railflg    | character varying(1)   |
 roadflg    | character varying(1)   |
 olfflg     | character varying(1)   |
 passflg    | character varying(1)   |
 divroad    | character varying(1)   |
 exttyp     | character varying(1)   |
 deckedroad | character varying(1)   |
 artpath    | character varying(1)   |
 persist    | character varying(1)   |
 gcseflg    | character varying(1)   |
 offsetl    | character varying(1)   |
 offsetr    | character varying(1)   |
 tnidf      | bigint                 |
 tnidt      | bigint                 |
 the_geom   | public.geometry        |
                                      Table "tiger.addr"
nextval('public.addr_gid_seq'::regclass)
 tlid      | bigint                |
 fromhn    | character varying(12) |
 tohn      | character varying(12) |
 side      | character varying(1)  |
 zip       | character varying(5)  |
 plus4     | character varying(4)  |
 fromtyp   | character varying(1)  |
 totyp     | character varying(1)  |
 fromarmid | integer               |
 toarmid   | integer               |
 arid      | character varying(22) |
 statefp   | character varying(2)  | not null
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
