[postgis-users] Import geometry problems
Nicklas Avén nicklas.aven at jordogskog.no
Sat Feb 27 10:32:25 PST 2010
Hallo Tim  What do you mean by "not working". That the cell seems to be empty is just something pgAdmin does for big geometries.It still is there.  You can test it by running for example:select ST_Length(the_geom) from "infra"."linienverlauf_gis_temp"; If you get a length value for each row there is no problem. Hope that helpsNicklas
2010-02-27 Tim Semmelhaack wrote:
Hello,
>I created a sql-file with shp2pgsql from a ArcGIS-Shapefile with linestrings.
>Some datasets compromises long strings in the geometry field (> 5000 characters)
>After the import the geometry is blank, others fields with a shorter
>string are filled.
>I attached the sql-file, (the geometry looks strange but these are bus
>routes in the rural area !).
>The first dataset doesn't work, the second one does.
>I've created the files with windows but also with linux - same result.
>Any explanations, suggestions?
>Tim
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100227/328f9dd3/attachment.html>
