[postgis-users] negative buffer
olivier dorie olivier.dorie at ign.fr
Tue Jan 5 09:37:41 PST 2010
Hi all,
The following query (negative buffer) stop my current postgreSQL connection
and rollback the other connections:
select buffer(geomfromtext('MULTIPOLYGON(((410397.744442313
6274725.08312074,410396.9 6274728.9,410393.2 6274737.5,410386.7
6274747.5,410376.5 6274759.7,410368.5 6274770.4,410361.2 6274781,410354.6
6274801.5,410354.5 6274815.3,410355.4 6274824.4,410357.3 6274834.8,410360.1
6274843.9,410368 6274859.8,410372 6274865.6,410385.4 6274880.6,410389.4
6274886.4,410394.6 6274895.1,410400.7 6274902.2,410408 6274908.3,410416.3
6274912.1,410423.9 6274911.8,410432.5 6274910.3,410440.3 6274911.1,410449.4
6274911.8,410460.5 6274910.7,410468.9 6274909,410478.1 6274908.1,410487.6
6274907.7,410495 6274905.7,410503.3 6274902.9,410512.5 6274899.9,410522.3
6274893.9,410529.3 6274888.3,410533.7 6274881.4,410537 6274871.1,410539
6274857.7,410540.8 6274846.7,410544.3 6274832.9,410547.8 6274822.8,410554.4
6274809.9,410559.4 6274799.7,410565.7 6274785.2,410570 6274772.3,410574
6274759.1,410578.5 6274751.9,410583.8 6274746.2,410594 6274741.2,410602.6
6274737.7,410610.2 6274733.8,410617 6274729.3,410624.5 6274722.2,410630
6274713.1,410633.1 6274700.9,410634 6274690.3,410633.7 6274679.4,410631.2
6274670.3,410627.3 6274664.7,410621 6274658.7,410616.8 6274652.8,410611.8
6274642.2,410607 6274625.3,410605.7 6274615.8,410605.6 6274608.6,410607.1
6274601.2,410609.8 6274593.5,410614.1 6274582.6,410617.6 6274573.2,410621
6274565.2,410624.3 6274560.4,410628.7 6274556.7,410633.4 6274554.1,410639.5
6274551.3,410646.3 6274549,410653.5 6274547.4,410660.1 6274546.8,410666.4
6274547.5,410682.1 6274552.7,410697.7 6274561.1,410705.4 6274565.6,410714.6
6274570.3,410736.4 6274578.5,410767.8 6274588.7,410792 6274600.5,410815.7
6274608.1,410831.7 6274612.3,410840.3 6274613,410852.2 6274612.7,410861
6274610.6,410869.8 6274605.9,410878.5 6274598.9,410884.7 6274594.9,410892.1
6274592.2,410898.4 6274590.1,410906.1 6274587.8,410912.2 6274586.1,410918.9
6274584.1,410925.4 6274583.4,410930.1 6274583.7,410939.8 6274583.6,410946.4
6274583.2,410952.1 6274581.5,410957.5 6274578.6,410963.5 6274573.5,410968.6
6274567.2,410976.4 6274558.7,410984.3 6274552,410989.5 6274549,410992.6
6274513.4,410986.699538985 6274495.74400512,410991.4 6274515,410916.6
6274530.6,410837.1 6274581.2,410822.1 6274581.3,410787.1 6274572.6,410715.9
6274538.2,410670.8 6274528.6,410631 6274543.9,410596.4 6274584.2,410592
6274664.1,410548.7 6274739.4,410514.6 6274844.6,410489.8 6274870.7,410455
6274886,410410.1 6274891.4,410395 6274881.5,410373.8 6274846.7,410373.4
6274806.8,410397.9 6274740.6,410397.744442313 6274725.08312074)),((410213.2
6274758.1,410235.4 6274718.7,410236.2 6274713.3,410239.3 6274701,410246.8
6274691.1,410251.7 6274684.6,410256.4 6274676.6,410260.6 6274667.3,410263.3
6274657.3,410263.9 6274645.6,410264.4 6274636.1,410266.2 6274628.1,410270.2
6274621.4,410275.4 6274617.3,410280.2 6274614.9,410286.4 6274614.6,410300.8
6274617.9,410309.5 6274619,410319.4 6274621.5,410328.7 6274624.8,410339.4
6274633.2,410345 6274640.4,410352.8 6274650.1,410361.7 6274660.9,410369
6274668.7,410378.3 6274678.4,410382.6 6274682.6,410388.6 6274687.9,410392.9
6274693.8,410396.2 6274702.2,410397.563140393 6274706.99825418,410397.5
6274700.7,410382.3 6274665.8,410347 6274631.2,410291.8 6274591.7,410276.7
6274586.8,410242.2 6274633,410217.6 6274688.2,410213.2
6274758.1)))',-1),-25);
The message is the following :
server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
Therefore the multipolygon is valid (function isvalid).
If I try buffer on the 2 polygons separately, it works. One result is empty
polygon.
Is there a problem with this object, with my installation, with my query or
negative buffer?
Best
Olivier
PS: I'm using postgreSQL 8.3.7, Postgis 1.3.4 et geos 3.0.3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100105/76ec026b/attachment.html>
