[postgis-users] pgsql2shp usage
Anisha Kaul anisha.kaul at hitechroboticsystemz.com
Sun Jan 10 23:22:48 PST 2010
Many thanks to all of you for bothering to reply !!
>From Chris Hermansen
> Anisha, why are you converting to shape file?
I failed to load the map directly from the database !
So I thought it will be a boostup for me if I manage to load the map from a shape file, and then I can go for the
database reading !
I didn't have any problem in loading a world map from a shape file directly downloaded from the internet, but I
am facing problems when I convert the postgres data in a shape file and then try to load it.
>From Regina
> Never worked with osm data, but since I created the .prj generator in
> pgsql2shp, I can tell you it reads the srid of the geometry and looks up the
> srtext in spatial ref and outputs that to the .prj file.
> I suspect osm data is in Mercator not long lat.  If you want your output to
> be in long lat, you need to transform and use an sql statement
> pgsql2shp -f "/path/to/filename" -h myserver -u apguser -P apgpassword
> mygisdb
> 	"SELECT field1 AS hs_num, field2...., ST_Transform(the_geom,4326) As
> the_geom FROM planet_osm_line"
I tried what u said as follows:
pgsql2shp -f ../data/myfile gis "SELECT *, ST_Transform(way,4326) As the_geom FROM planet_osm_line"
Preparing table for user query... Failed: ERROR:  AddToPROJ4SRSCache: Cannot find SRID (4326) in spatial_ref_sys
Then With reference to this http://postgis.refractions.net/pipermail/postgis-users/2008-February/018486.html web
page I executed the following in the postgres database
gis=# SELECT UpdateGeometrySRID ('public', 'planet_osm_polygon','way', 4236);
ERROR:  constraint "enforce_srid_way" of relation "planet_osm_polygon" does not exist
CONTEXT:  SQL statement "ALTER TABLE public.planet_osm_polygon DROP constraint enforce_srid_way"
PL/pgSQL function "updategeometrysrid" line 53 at EXECUTE statement
SQL statement "SELECT UpdateGeometrySRID('', $1 , $2 , $3 , $4 )"
PL/pgSQL function "updategeometrysrid" line 4 at SQL statement
I don't know what to do now, please guide !
Anisha Kaul
Hi-Tech Gears Limited, Gurgaon, India
