[postgis-users] Problems with Udig connecting to PostGIS 1.4
Roger André randre at gmail.com
Tue Jan 12 13:08:39 PST 2010
Hi All,
I'm encountering something I've not seen before; Udig having problems
connecting to PostGIS.  I'm running a Ubuntu 9.10 box with
udig-1.1.1-linux.gtk.x86, postgresql-8.4.2, and postgis-1.4.1.  Postgis is
up and running, and seems to be working properly (able to load, unload,
query, etc).  However, when I try to add a PostGIS layer in Udig, the
application just sits and spins.
Is there some sort of new connection parameter in PostGIS that needs to be
set before Udig will connect to it?  I'm able to connect with ogr2ogr just
fine, so I'm not sure whet else to check.
Thanks,
Roger
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100112/ad0ea13e/attachment.html>
