[postgis-users] Questions about using SRID not -1
Oscar Zamudio cmntlk at gmail.com
Sat Jan 16 22:23:18 PST 2010
Thanks Oliver but I already tried that with the sentence:
SELECT UpdateGeometrySRID('mypoints', 'srid', 4326);
(following instructioms: *UpdateGeometrySRID*(varchar table_name, varchar
column_name, integer srid);)
I got the following message
ERROR: column not found in geometry_columns table
SQL state: P0001
Context: SQL statement "SELECT UpdateGeometrySRID('','', $1 , $2 , $3 )"
PL/pgSQL function "updategeometrysrid" line 4 at SQL statement
I don't know what's happpening....
On Sat, Jan 16, 2010 at 4:00 PM, Olivier Courtin <
olivier.courtin at oslandia.com> wrote:
> On Jan 16, 2010, at 7:54 PM, Oscar Zamudio wrote:
> Hi Oscar.
>  Ok, when I insert my points in my spatial enabled database I used:
>> without no spatial reference system explicit so I guess the SRID is set to
>> "unknown" i.e. -1.  Then naively I created a new column named srid for my
>> table and put the right value of SRID
> SRID information is stored *both* in the geometry_columns table (srid
> column),
> and inside each geometry itself.
> So consider using UpdateGeometrySRID function to fix your issue.
> http://postgis.refractions.net/documentation/manual-svn/UpdateGeometrySRID.html
> HTH,
> Olivier
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100117/a926a36d/attachment.html>
