[postgis-users] Finding if a polygons is fully covered by others
Nicolas Gillet - MARKET-IP nicolas.gillet at market-ip.com
Mon Jan 18 01:23:16 PST 2010
Hello,
I am looking for some help in optimizing a query.
I have a table with bounding boxes and sometimes I need to find if a new
given polygon can be fully covered by existing bounding boxes of my table.
Right now I can find it out by summing the areas of intersections between my
polygon and those in my table and comparing this computed area with my
polygon area.
Here's the query :
SELECT ST_area(ST_GeometryFromText('POLYGON((-1 0, -1 1, 1 1, 1 0, -1 0))',
4326) ) -
(SELECT SUM(st_area(st_intersection(the_geom,
ST_GeometryFromText('POLYGON((-1 0, -1 1, 1 1, 1 0, -1 0))', 4326) ) ))
                FROM tests WHERE the_geom &&
=> if query returns 0 then my polygon can be fully covered if != 0 then it
can't.
But I was wondering if there couldn't be an easier way to do this.
Thank you.
Nicolas.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100118/c0ebef85/attachment.html>
