[postgis-users] Questions about using SRID not -1
Oscar Zamudio cmntlk at gmail.com
Thu Jan 21 12:21:10 PST 2010
UpdateGeometry didn't work.
On Thu, Jan 21, 2010 at 4:34 PM, Chris Hermansen <
chris.hermansen at timberline.ca> wrote:
> The problem is, the kind of transforms you want to do (to UTM for example)
> only work when there is a valid SRID in the table geometry and in the
> geometry_columns table, and the two agree.  AFAIK anyway.
> I suggested that you try the UpdateGeometrySRID() function as per
> http://www.postgis.org/documentation/manual-1.4/UpdateGeometrySRID.html
> but I don't see any comment on whether that worked for you.
> Also, did you try the manual process (you might have to do this prior to
> using UpdateGeometrySRID())
> http://www.postgis.org/documentation/manual-1.4/ch04.html#Manual_Register_Spatial_Column
> Oscar Zamudio wrote:
>> I already stated that this is only an experiment trying to solve the
>> problem because my customer already loaded a lot of data WITHOUT expliciting
>> SRID reference..... I mean,
>> INSERT INTO mydistance (the_geom, the_name) VALUES
>> (ST_GeomFromText('POINT(-58.0 0.0)',4326),'Punto 1-1');
>> Is a step without SRID value that was taken years ago on their database.
>> I'm trying to avoid the reloading process and taking in account that there
>> are some functions that probably can make the task,,, I began to explore
>> them without success up to now.
>> Regards,
>> On Thu, Jan 21, 2010 at 3:55 PM, Chris Hermansen <
>> chris.hermansen at timberline.ca <mailto:chris.hermansen at timberline.ca>>
>> wrote:
>>    Oscar;
>>    Read this:
>> http://www.postgis.org/documentation/manual-1.4/ch04.html#Create_Spatial_Table
>>    Note the use of the AddGeometryColumn() to put a geometry column
>>    on your table and put an entry in the geometry_columns table,
>>    including setting the SRID correctly.
>>    So your example might be
>>    CREATE TABLE mydistance (the_name text);
>>    SELECT AddGeometryColumn('mydistance','the_geom',4326,'POINT',2);
>>    etc assuming you wanted SRID 4326.
>>    The next section tells you how to manually register a geometry
>>    column if you have created it manually.
>>        Hi, Two things. First, the name of the table in the INSERTS
>>        sentences is 'mypoints', not 'mydistance'. Second: I tried
>>        what Ibrahim suggested:
>>        Select st_xmin(the_geom), st_ymin(the_geom) from mypoints
>>        And the results are:
>>        -58;0
>>        -57;0
>>        -58;-45
>>        -57;-45
>>        -58;-90
>>        -57;-90
>>        So, none of them (as was expected) is out of the geometry
>>        projection reference.
>>        On Thu, Jan 21, 2010 at 2:38 PM, Oscar Zamudio
>>        <cmntlk at gmail.com <mailto:cmntlk at gmail.com>
>>        <mailto:cmntlk at gmail.com <mailto:cmntlk at gmail.com>>> wrote:
>>           Hi, me again!
>>           Well at first it cannot be possible to have more than one
>>           projection. For clarity, let explain wht I did to reach at
>>        this point:
>>           1- First I created a database 'mydistances' using
>>        postgis_template
>>           as template for it.
>>           2-Create a table 'mypoints' with two columns: 'the_name' and
>>            "the_geom"
>>           3- Load some GIS data:
>>               INSERT INTO mydistance ( the_geom, the_name ) VALUES (
>>               ST_GeomFromText('POINT(-58.0 0.0)'), 'Punto 1-1');
>>               ST_GeomFromText('POINT(-57.0 0.0)'), 'Punto 1-2');
>>               ST_GeomFromText('POINT(-58.0 -45.0)'), 'Punto 2-1');
>>               ST_GeomFromText('POINT(-57.0 -45.0)'), 'Punto 2-2');
>>               ST_GeomFromText('POINT(-58.0 -90.0)'), 'Punto 3-1');
>>               ST_GeomFromText('POINT(-57.0 -90.0)'), 'Punto 3-2');
>>           It can be seen there's no SRID indication and that no value
>>        is out
>>           of the 4326 projection reference.
>>           4- Tried to measure distances between those points usin
>>           ST_Distance. As all those data are in 4326 the retured
>>        values are
>>           in sexagesimal degrees.
>>           5- Tried to use ST_Transform to UTM projections to get the
>>           distances in meters and all my problems began.
>>           6- I want to get the distances in meters reprojecting the
>>        points
>>           and not calculating the meters form the degrees as this
>>           calculation depends of the UTM zone. I know which zone is
>>        in each
>>           case and there exists the ST_Transform function so, it is
>>        easy to
>>           avoid additional external calculations and obtain directly from
>>           the database my results.
>>           7- Tried all the recipes I got from you without success.
>>           Can anybody see what it is the problem with this schema?
>>           On Thu, Jan 21, 2010 at 4:07 AM, ibrahim saricicek
>>           <ibrahimsaricicek at gmail.com
>>        <mailto:ibrahimsaricicek at gmail.com>
>>        <mailto:ibrahimsaricicek at gmail.com>>>
>>           wrote:
>>               Hi;
>>               No you can change projection any time you want, the
>>        point on
>>               your table is;
>>               You have objects in different projections but in one table.
>>               You have to find which objects are 4326 projection, and
>>        which
>>               are not...
>>               Another method may be;
>>               if the coordinates differ from -->
>>               Longitude
>>                180 W   = -180
>>                180 E   =  180
>>               Latitude
>>                 90 N   =   90
>>                 90 S   =  -90
>>               Namely your x not between -180 and 180 and y not
>>        between -90
>>               and 90, the objects are in an another projection.
>>               I mean firstly try to differ different projected objects..
>>               Regards,
>>               IBO...
>>                             On Thu, Jan 21, 2010 at 2:01 AM, Oscar Zamudio
>>                   Hi,
>>                   I tried:
>>                   UPDATE  mypoints SET
>>        the_geom_4326=transform(the_geom,4326)
>>                   But again I got:
>>                   ERROR:  Input geometry has unknown (-1) SRID
>>                   It seems that once the data is without explicit
>>        SRID, they
>>                   cannot be processed later for asigning a proper SRID.
>>                   It is strange at first sight....but I'm a newbie so I
>>                   don't know much about this.
>>                   Regards,
>>                               Oscar
>>                               On Tue, Jan 19, 2010 at 6:27 AM,
>>        ibrahim saricicek
>>        <mailto:ibrahimsaricicek at gmail.com>>> wrote:
>>                       Hi,
>>                                       Your table include objects,
>>        more than one projection..
>>                       So if there is any object in different
>>        projection you
>>                       can't set your table projection to 4326...
>>                                       can you try this!!
>>                                       Create a new geometry column
>>        "the_geom_4326"
>>                                       then run this
>>                                       UPDATE  table_name SET
>>                       the_geom_4326=transform(the_geom,4326),
>>                                       then use ST_SetSRID for the new
>>        column...
>>                                       REgards,
>>                       ibo...
>>                                                       On Mon, Jan 18,
>>        2010 at 7:23 PM, Oscar Zamudio
>>                           Hi everybody.
>>                           I had no success with any of the recipes
>>        received
>>                           here.
>>                           Could it be that a table with data loaded
>>        without
>>                           SRID explicit value has no chance of being
>>        updated
>>                           later to the right one?
>>                           Regards,
>>                           Oscar
>>                           On Sun, Jan 17, 2010 at 1:08 PM, Oscar Zamudio
>>                               Ben,
>>                               I tried your intruction:
>>                               UPDATE mypoints SET the_geom =
>>                               ST_SetSRID(the_geom,4326);
>>                               But I got:
>>                               ERROR:  Operation on two GEOMETRIES with
>>                               different SRIDs
>>                               Regards,
>>                               Oscar
>>                               On Sat, Jan 16, 2010 at 10:48 PM, Ben Madin
>>                               <lists at remoteinformation.com.au
>>        <mailto:lists at remoteinformation.com.au>
>>        <mailto:lists at remoteinformation.com.au>>> wrote:
>>                                   Oscar,
>>                                   you have a couple of options as I
>>        see it.
>>                                   In Postgres you could just update the
>>                                   geometries first.
>>                                   > UPDATE mytable SET the_geom =
>>                                   And for next time, assuming your data
>>                                   originally had some sort of coordinate
>>                                   system (and it must have if it was
>>        spatial
>>                                   data), you can / should use the -s
>>        flag in
>>                                   shp2pgsql to provide 'SRID awareness'
>>                                   In your case, I would suggest -s 4326.
>>                                   ie (using -d to drop and replace
>>        existing
>>                                   table
>>                                   $ shp2pgsql -s 4326 -d myshapefile
>>                                   myoldtablename | psql mydatabase
>>                                   In geometry terms, I think it is
>>        unlikely
>>                                   that your data was stored
>>        (spatially) as
>>                                   sexagesimal degrees, although it may be
>>                                   displayed as such in your GIS.
>>                                   cheers
>>                                   Ben
>>                                   On 17/01/2010, at 2:54 , Oscar
>>        Zamudio wrote:
>>                                   > Hi,
>>                                   > I'm have problems to transform my
>>                                   spatial data to UTM. First, this
>>                                   instruction works OK:
>>                                   > SELECT
>>                                   ST_Transform(ST_GeomFromText('POINT(0.0
>>                                   20)',4326),22171) from mypoints
>>                                   > No matter if such a sentence has no
>>                                   meaning on what I tryin to do.  But
>>        when I
>>                                   did the same with my own points:
>>                                   > SELECT
>> ST_Transform(mypoints.the_geom,22171) from
>>                                   mypoints
>>                                   > I get the following error:
>>        (-1) SRID
>>                                   > SQL state: XX000
>>                                   > Ok, when I insert my points in my
>>                                   spatial enabled database I used:
>>                                   the_name ) VALUES (
>>                                   'Punto 1-1');
>>                                   > without no spatial reference system
>>                                   explicit so I guess the SRID is set to
>>                                   "unknown" i.e. -1.  Then naively I
>>        created
>>                                   a new column named srid for my
>>        table and
>>                                   put the right value of SRID for all my
>>                                   data which is 4326 (WGS84, sexagesimal
>>                                   degrees lat lon) in that column but
>>        still
>>                                   I get the same error. After that I
>>        created
>>                                   a constraint between this new srid
>>        column
>>                                   and the srid column from the
>>                                   spatial_ref_sys table but nothing
>>                                   happened, the error is still there.
>>                                   > It's important to me to solve
>>        this issue
>>                                   because all my spatial data was loaded
>>                                   from shapefiles without SRID
>>        awareness so
>>                                   they don't have any SRID column. I
>>        don't
>>                                   want to reload data changing this so I
>>                                   need a method to alter the tables
>>        in such
>>                                   a way to add this new srid column
>>        to them
>>                                   that is well related to the spatial
>>        context.
>>                                   > Thanks and regards,
>>                                   > Oscar
>>                                   > postgis-users mailing list
>>        postgis-users at postgis.refractions.net
>>        <mailto:postgis-users at postgis.refractions.net>
>>                                         <mailto:
>>        <mailto:postgis-users at postgis.refractions.net>>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>                                         <mailto:
>>                                 <mailto:
>>    --    Regards,
>>    Chris Hermansen · chris.hermansen at timberline.ca
>>    <mailto:chris.hermansen at timberline.ca> · skype:clhermansen
>>    tel+1.604.714.2878   ·  fax+1.604.733.0631   ·   mob+1.778.840.4625
>>    Timberline Natural Resource Group Ltd   ·  http://www.timberline.ca
>>    401  ·  958 West 8th Avenue  ·  Vancouver BC  ·  Canada  ·  V5Z 1E5
> Regards,
> Chris Hermansen · chris.hermansen at timberline.ca · skype:clhermansen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100121/4a0a0510/attachment.html>
