[postgis-users] Connecting uDig to PostGIS .
Anders Söderman Anders.Soderman at gisassistans.se
Sun Jan 24 11:37:09 PST 2010
Thanks Nicklas – you put me on the right track!
It seems like uDig doesn´t like long names or to many “_” or capital letters
for PostGIS Databases.
After changing SNV_AB_lan_Skyddad_natur_POLY_s99TM to
snv_ab_lan_skyddad_naturpoly_s99tm. My guess is capital letters.
Anders Soderman
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Nicklas
Avén
Sent: den 24 januari 2010 17:19
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Connecting uDig to PostGIS .
Hallo Anders
Can you check if all tables is represented in table geometry_columns in
public schema, or maybe if only those that you can load is represented.
If so the quick fix is to run
Select Populate_Geometry_Columns();
if your tables are big it might take some time because it will look through
all your tables and add nessecery information to table geometry_columns.
Then you should restart udig and try agian.
But it would be great if you checked first if the tables are represented in
geometry_columns.
Hope that helps
/Nicklas
2010-01-24 Anders Söderman wrote:
Hello.
I am learning SLD (Styled Layer Descriptor) and therefore Im building a
PostGIS testdatabase for GeoServer and uDig. uDig gives me a SLD XML-file to
work with, that why uDig is important.
I have 17 Databases in PostGIS but only two could be imported into the uDig
Catalog. One table/layer in a third Database was loaded to, but the other 17
tables/layers in the same Database was rejected.  I have a feeling that the
ones who succeded was loaded into PostGIS in December last year using
shp2pgsql or QGIS/SPIT. For the rest I have been using shp2pgsql_gui, which
saves so much time.  I´ve installed uDig on a second PC and the result was
exactly the same. uDig says: Unable to recognize service, choose another.
 I´ve been testing and reading manuals for two days, but now I´m out of
ideas. Anybody who could give me a new direction?    Thanks Anders Soderman
Sweden
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100124/e14b9130/attachment.html>
