[postgis-users] update an st_intersects
Rafael Soto rafael.soto at gmail.com
Tue Jan 26 04:30:26 PST 2010
Try it
update poi set province_id=(
select province.ogc_fid from province where intersects(poi.the_geom,
province.the_geom)=True group by province.ogc_fid
On Tue, Jan 26, 2010 at 10:26 AM, ibrahim saricicek <
ibrahimsaricicek at gmail.com> wrote:
> Hi all,
> Thanks, understand.
> Ok, is there another way to update poi's province.ogc_fid with the bounding
> province's ogc_fid ???
> Namely i want to learn the province of POI's...
> Regards..
> On Tue, Jan 26, 2010 at 2:20 PM, Rafael Soto <rafael.soto at gmail.com>wrote:
>> Hello my friend..
>> Your query is not wrong but your record true..
>> When you call a subselect to complete your UPDATE operation, this
>> subselect can be only one row in result return.
>> To correct this, you must be define one filter to decide what the result
>> you want to UPDATE.
>> To see the mistake, execute a subselect {{{ select*  province.ogc_fid
>> from province,poi where intersects(poi.the_geom, province.the_geom)=True
>> group by province.ogc_fid* }} and check the number of rows in the
>> resultset.
>> On Tue, Jan 26, 2010 at 9:57 AM, ibrahim saricicek <
>>> Hi all,
>>> I have two tables; provinces an points of interests. I wanna update
>>> province_id column with st_intersects function..
>>> My sql;
>>> select province.ogc_fid from province,poi where intersects(poi.the_geom,
>>> The message is
>>> ERROR: more than one row returned by a subquery used as an expression
>>> What should I change?
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Rafael Soto
Rafael Soto
Sent from Brasilia, DF, Brazil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100126/109fa2f4/attachment.html>
