[postgis-users] update an st_intersects
Suhr, Ralf Ralf.Suhr at itc-halle.de
Tue Jan 26 06:29:58 PST 2010
UPDATE poi set province_id = sub.id
FROM
SELECT DISTINCT province.ogc_fid AS id
FROM province
WHERE ST_Intersects(poi.the_geom, province.the_geom)
) AS sub
WHERE province_id = sub.id
Gr
Ralf
Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
ibrahim saricicek
Gesendet: Dienstag, 26. Januar 2010 15:11
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] update an st_intersects
Hi all,
The same error
ERROR: more than one row returned by a subquery used as an expression
any comments?
On Tue, Jan 26, 2010 at 2:30 PM, Rafael Soto <rafael.soto at gmail.com>
wrote:
Try it
update poi set province_id=(
select province.ogc_fid from province where intersects(poi.the_geom,
province.the_geom)=True group by province.ogc_fid
On Tue, Jan 26, 2010 at 10:26 AM, ibrahim saricicek
<ibrahimsaricicek at gmail.com> wrote:
Hi all,
Thanks, understand.
Ok, is there another way to update poi's province.ogc_fid with the
bounding province's ogc_fid ???
Namely i want to learn the province of POI's...
Regards..
On Tue, Jan 26, 2010 at 2:20 PM, Rafael Soto <rafael.soto at gmail.com>
wrote:
Hello my friend..
Your query is not wrong but your record true..
When you call a subselect to complete your UPDATE operation, this
subselect can be only one row in result return.
To correct this, you must be define one filter to decide what the result
you want to UPDATE.
To see the mistake, execute a subselect {{{ select  province.ogc_fid
from province,poi where intersects(poi.the_geom, province.the_geom)=True
group by province.ogc_fid }} and check the number of rows in the
resultset.
On Tue, Jan 26, 2010 at 9:57 AM, ibrahim saricicek
	Hi all,
	I have two tables; provinces an points of interests. I wanna
update province_id column with st_intersects function..
	My sql;
	select province.ogc_fid from province,poi where
intersects(poi.the_geom, province.the_geom)=True group by
province.ogc_fid
	The message is
expression
	What should I change?
	postgis-users mailing list
	postgis-users at postgis.refractions.net
	http://postgis.refractions.net/mailman/listinfo/postgis-users
Rafael Soto
Rafael Soto
Sent from Brasilia, DF, Brazil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100126/3d7a73a9/attachment.html>
