[postgis-users] decimal degrees to dms
Simon Greener
simon at spatialdbadvisor.com
Thu Jan 28 01:10:11 PST 2010
Don,
You've probably already solved this but perhaps you could use a plPgSQL function or two like this:
Create Function gis.DMS2DD( dDeg In Float,
dMin In Float,
dSec In Float)
Returns Float
AS
$BODY$
Declare
dDD Float;
BEGIN
dDD := ABS(dDeg) + dMin / 60::float + dSec / 3600::float;
Return SIGN(dDeg) * dDD;
End;
$BODY$
LANGUAGE 'plpgsql' IMMUTABLE STRICT
COST 100;
SELECT gis.DMS2DD(-44,10,50);
SELECT gis.DMS2DD(-44,00,00);
Create or Replace Function gis.DD2DMS( dDecDeg in Float,
pDegreeSymbol in VarChar(1),
pMinuteSymbol in VarChar(1),
pSecondSymbol in VarChar(1) )
Returns varchar(50)
AS
$BODY$
DECLARE
iDeg Int;
iMin Int;
dSec Float;
BEGIN
iDeg := Trunc(dDecDeg)::Int;
iMin := Trunc( (Abs(dDecDeg) - Abs(iDeg)) * 60)::Int;
dSec := Round(((((Abs(dDecDeg) - Abs(iDeg)) * 60) - iMin) * 60)::numeric, 3)::float;
Return trim(to_char(iDeg,'9999')) || pDegreeSymbol::text || trim(to_char(iMin,'99')) || pMinuteSymbol::text || case when dSec = 0::Float then '0' else replace(trim(to_char(dSec,'99.999')),'.000','') end || pSecondSymbol::text;
END;
$BODY$
COST 100;
select gis.DD2DMS(-44,'d','m','s');
select gis.DD2DMS(-44.5,'d','m','s');
select gis.DD2DMS(-44.577,'d','m','s');
select gis.DD2DMS(gis.DMS2DD(-44,10,50),'d','s','"');
regards
Simon
On Tue, 26 Jan 2010 23:01:44 +1100, Don <harterc1 at comcast.net> wrote:
> I haven't been able to find a function that will convert a decimal
> latitude or longitude to degrees minutes seconds.
> Am I missing something? I am doing a query and get complicated
> expressions like
> lpad((round((((abs(long_wgs84)-floor(abs(long_wgs84)))*60::double
> precision - floor((abs(long_wgs84)-floor(abs(long_wgs84)))*60::double
> precision))*60::double precision)::numeric,1)*10::real)::text,3,'0')
> for seconds decimal rounded*10 padded
> to get the seconds for the following format ddmmsss.
> postgis-users mailing list
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
