[postgis-users] Jython?
Ivan Willig iwillig at opengeo.org
Thu Jul 1 08:47:56 PDT 2010
Hi Guyren,
For spatial analysis in jython I would check out Justin Deolive's
GeoScript jython project.
http://geoscript.org/py/
It uses JTS and GeoTools. If you are looking to use jruby and geo, you
could always try using JTS in jruby. It should work fine.
Hope this helps.
Ivan Willig
OpenGeo
On Wed, Jun 30, 2010 at 07:10:02PM -0700, Guyren G Howe wrote:
> I'm just in the early stages of a project for which a variety of geographical reasoning will be needed. I normally work in Rails, but the project is started in TurboGears so we can use all the geographic Python stuff.
> But then it occurred to me that I could do the project mostly in Rails and do the geographic stuff in Python, if I used JRuby and Jython. This will let me just get the thing done, rather than have to spend my time learning TurboGears first (it appears to be a fine framework, but the community and documentation are not nearly as robust as those for Rails).
> So my question is: how well would it work to use Jython for GIS?
> postgis-users mailing list
