[postgis-users] custom EPSG codes?
Robert Coup robert.coup at koordinates.com
Mon Jul 19 14:10:14 PDT 2010
On Tue, Jul 20, 2010 at 8:06 AM, chrispg <chrisemberson at hotmail.com> wrote:
> I have data in British Nat Grid that I would like to load into postgis.
> Normally I would use EPSG:27700 to do this no problem, but the coordinates
> are to decimetre precision, not metre, so 27700 is out by a factor of 10. I
> can edit the spatial_ref_sys.sql to generate a custom projection file, but
> then performing any queries on that using the PROJ4 libraries are a problem
> as it is not recognised. Has anybody come across this before?
Maybe add your new projection to the proj4 library as well?
Copy the 27700 line from /usr/share/proj/epsg to /usr/share/proj/my using a
new number (eg. 927700), set the same number in spatial_ref_sys, and then
use +init=my:927700 with proj4, and srid=927700 in postgis...
If decimeters are regularly used in datasets, consider submitting to
http://www.epsg.org/ to get assigned an "official" number.
Rob :)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100720/01b222dd/attachment.html>
