[postgis-users] Using grids transformation method with PostGis
Wed Jun 9 08:44:14 PDT 2010
Luís de Sousa wrote:
> Before I go, I just want to make sure that in principle PostGis should
> be able to use the grid files simply by the indication of its
> location, no additional configurations needed. Is this correct?
Luís,
I believe it should work fine with no special configuration.
Best regards,
