[postgis-users] Re : Re : Re : Re : PosGISViewer plugin PgAdmin III
jrmrolland at aol.com jrmrolland at aol.com
Fri Jun 11 06:43:17 PDT 2010
ok, for me (and for the PostGISViewer plugin) the geometry_columns table is always in the public schema,
so if $$SCHEMA=userdata (your schema), you don't have to pass 2 schema, but only your schema if you
select a table.
For a query you must specifiy the schema with the table name like this :
SELECT * FROM userdata.your_table
 Jérôme
-----E-mail d'origine-----
De : Bruno Friedmann <bruno at ioda-net.ch>
A : PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Envoyé le : Vendredi, 11 Juin 2010 13:38
Sujet : Re: [postgis-users] Re : Re : Re : PosGISViewer plugin PgAdmin III
On 06/11/2010 01:19 PM, jrmrolland at aol.com wrote:
> yes of course, public is just an sample, you can specifiy another schema if
you want.
> Jérôme
but the question is : we need to pass 2 schemas as public contain
geometry_columns table and userdata the table containing data ...
did this work also on a actual running installation
(Sorry didn't have any windows here ... )
     Bruno Friedmann
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100611/1afc32fb/attachment.html>
