[postgis-users] configure postgis for editing outside LAN
Nicolas Ribot nicolas.ribot at gmail.com
Mon Mar 1 01:34:45 PST 2010
On 9 February 2010 10:59, maning sambale <emmanuel.sambale at gmail.com> wrote:
> Hi,
> First post, newbie.
> I was able to finally install PostGIS and can already access my dbase
> via LAN.  I want to be able access the data outside LAN.  I played
> around with the pg_hba.conf and now I cannot access postgis database
> via pgadmin3 directly in the server machine!
> Current setup is:
> # TYPE  DATABASE    USER        CIDR-ADDRESS          METHOD
> # "local" is for Unix domain socket connections only
> local    all     all     trust
> # IPv4 local connections:
> #host    all     all     127.168.199     trust
> # IPv6 local connections:
> host     all     all     ::1/128         trust
> host     all     all     192.168.1.0/24 trust
> Any ideas
Did you check if any firewall is present and allow traffic on PG port ?
Also, did you change the "listen_addresses" parameter in postgresql.conf ?
Nicolas
