[postgis-users] Postgis: Error
Majid Kazemi Majid.Kazemi at teranet.ca
Mon Mar 8 08:37:01 PST 2010
Thanks very much for all updates.
I found the libgeos_c.so.1 in /usr/local/lib.
I exported LD_LIBRARY_PATH=/usr/local/lib but I am still having the same
issue.
Yes, I run ldconfig as root. It did not see any update or error.
What this suppose to do?
Thanks, Majid
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of strk
Sent: March 5, 2010 6:27 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Postgis: Error
On Fri, Mar 05, 2010 at 04:11:25PM -0500, Majid Kazemi wrote:
> l:57: ERROR:  could not load library
> "/opt/PostgreSQL/8.3/lib/postgresql/postgis-1.5.so": libgeos_c.so.1:
> cannot open shared object file: No such file or directory
Did you run ldconfig(8) after geos install ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
