[postgis-users] Converting UTM to lat/lon using Postgis
pcreso at pcreso.com pcreso at pcreso.com
Mon May 3 10:02:55 PDT 2010
See:
http://www.spatialreference.org/ref/epsg/3997/postgis/
for the insert statement to create this projection in Postgis.
For other information about this projection see:
HTH,
  Brent Wood
--- On Mon, 5/3/10, Mehmet Erkek <merkek at reidin.com> wrote:
Subject: Re: [postgis-users] Converting UTM to lat/lon using Postgis
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Monday, May 3, 2010, 7:50 PM
Thank you for the fast answer!
Hmm. It looks I don’t have srid 3997 in the DB.
=# select srid, srtext, proj4text from spatial_ref_sys where
srid=3997;
 srid | srtext | proj4text
(0 rows)
srtext like '%Dubai%';
(0 rows)
Could this be related to my postgis installation?
I don’t see this srid in spatial_ref_sys.sql which came
with postgis installation either.
Any idea how I can fix this?
Mehmet ERKEK
www.REIDIN.com
postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Francis
Markham
Sent: Monday, May 03, 2010 11:09 AM
To: PostGIS Users Discussion
Hi Mehmet,
When you imported the shapefile, the SRID you are meant to specify is the SRID
of the data, not the SRID you want.  Since the data is in Dubai Local TM,
the SRID is 3997.  To get the transformation you want, try the following:
select
ST_AsText( ST_Transform(centroid(ST_SetSRID(the_geom, 3997)),4326)) from
ult.test2 limit 5;
Hope that helps,
-Francis
On 3 May 2010 17:03, Mehmet Erkek <merkek at reidin.com> wrote:
Hi
All,
I
havea a shape file which I imported it to a table called ‘test2’
(using  SRID=4326).  I want to get centroids of geometries in
lat/lon.
Here
is what I run:
select
ST_AsText( ST_Transform(centroid(the_geom),4326)) from ult.test2 limit 5;
and
what I get:
POINT(496597.996430787
2774798.21242881)
POINT(496332.629887436
2793339.61534586)
POINT(496302.627327975
2793317.82477318)
POINT(496305.255261594
2793353.29646291)
POINT(496241.538851096
2774826.65593589)
So
far all is fine except coordinates which are not  latitude/longitude
My
question is : How can I convert/get these coordinates in lat/lon?
This
what I have in my prj file:
PROJCS["Dubai
Local Transverse Mercator
(DLTM)",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",55.33333333333334],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
And
this is my postgis version: POSTGIS="1.3.6"
GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.7.1, 23 September 2009"
USE_STATS
I
appreciate any help. Thank you.
Mehmet ERKEK
www.REIDIN.com
This message is for the designated recipient only and may contain privileged,
proprietary, or otherwise private information. If you have received it in
error, please notify the sender immediately and delete the original. Any other
use of the email by you is prohibited. Please Consider the Environment Before
Printing This Email
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited.
Please Consider the Environment Before Printing This Email
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100503/46ad9bc5/attachment.html>
