[postgis-users] Dot Density idea
Ben Madin lists at remoteinformation.com.au
Thu May 6 08:42:26 PDT 2010
I have used an R function before (using maptools package) to do something similar, but I can't remember the details, so I would be considering looking at PL/R.
cheers
Ben
On 06/05/2010, at 15:40 , strk wrote:
> On Mon, May 03, 2010 at 10:49:32PM -0600, John Abraham wrote:
>> One of the things I miss about using ESRI's GIS is the ability to do dot-density maps.  Within a polygon, the number of dots is proportional to a value, and the dots are randomly placed.  I find it useful to be able to present several data values at once (e.g. blue dots for population, red dots for employment).
>> I also find that it is a more intuitive way of scaling for zone size than dividing the value by the area of the zone.  That is, the count of the dots represents the actual number, but the density of the dots represents the density of the number.  So I don't have to decide whether to divide the value by the area of the polygon to plot density: both the absolute number and the density are easily visible.
>> Since my open-source GIS viewing systems (mostly QGIS and Mapserver) won't plot dot-density, I've done without.
>> But today I realized that I can build these on the server instead.  I can generate random points within the bounding-box of the polygon, throwing out those that aren't contained within the polygon, repeating until I have enough.  Then I can save these points as a separate layer, and display this layer using almost any desktop or web based viewer!
>> Has anyone done this?  Can I do it in SQL or do I need to write something in PL/pgsql?
> PL/pgsql would be easier than SQL at the minimum.
> Still, a C implementation would likely be better, for speed reasons.
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
