[postgis-users] Dot Density idea
Martin Davis mbdavis at refractions.net
Thu May 6 15:11:29 PDT 2010
Check out this blog post for some images of different kinds of random
point fields:
http://lin-ear-th-inking.blogspot.com/2010/05/more-random-points-in-jts.html
Martin Davis wrote:
> Sounds like it could work - with maybe a bit of fiddling to deal with
> cases where the grid cells overlapped the polygon only slightly?
> Random perturbation by cell radius can still result in some points
> being very close together.  (And I think this would also be an issue
> where only a small part of each grid cell overlapped the polygon).
> This may or may not be desirable.  Perhaps a further check could be
> made to reduce the radius for points where this occurs.   Or maybe
> some sort of simulated annealing process could be use to push the
> points into a more even distribution.
> M
> Paul Ramsey wrote:
>> Even-yet-random :) nice requirement. How about just starting with a
>> regular grid and then perturbing the elements randomly with a radius
>> of a cell size? You can use the area of the polygon and number of
>> needed points to calculate the appropriate cell size and go from
>> there.
>> P
>> On Thu, May 6, 2010 at 10:28 AM, Martin Davis
>> <mbdavis at refractions.net> wrote:
>>> Good point about the need for even distribution of the points. That
>>> seems
>>> like a whole lot harder to code than simply randomly placing points
>>> in a
>>> polygon.  Does anyone have any pointers to algorithms for producing
>>> this
>>> effect?
>>> George Silva wrote:
>>>> The really big problem with dot density is that dots can overlap
>>>> themselves,
>>>> masking the real number, so if anything will be developed in this
>>>> area,
>>>> the
>>>> points should be
>>>> A) evenly distributed
>>>> or
>>>> B) randomly distributed, but with some sort of "colision" tests, so
>>>> there
>>>> is
>>>> no or little overlap.
>>>> This is a interesting idea, especially if we could make a materialized
>>>> view
>>>> with those points, which could be added to GIS software for
>>>> presentation.
>>>> George
>>>> On Thu, May 6, 2010 at 1:53 PM, Sufficool, Stanley <
>>>> ssufficool at rov.sbcounty.gov> wrote:
>>>>> Looks nasty, but it might work:
>>>>> select
>>>>> st_line_interpolate_point(
>>>>>       st_intersection(
>>>>>               the_geom,
>>>>>               st_makeline(
>>>>>                       st_pointn(st_exteriorring(the_geom),
>>>>> (rand1.rand *
>>>>> st_npoints(st_exteriorring(the_geom)))::int),
>>>>> (rand2.rand *
>>>>>       ,rand3.rand
>>>>> from insert_your_table_name_here,
>>>>> (select random() as rand, generate_series(1,1000) as point_number) as
>>>>> rand1
>>>>> JOIN (select random() as rand, generate_series(1,1000) as
>>>>> point_number)
>>>>> as
>>>>> rand2
>>>>>       ON rand1.point_number = rand2.point_number
>>>>> point_number)
>>>>> as
>>>>> rand3
>>>>>       ON rand2.point_number = rand3.point_number
>>>>> WHERE st_geometrytype(
>>>>>       st_intersection(
>>>>>               the_geom,
>>>>>               st_makeline(
>>>>> (rand1.rand *
>>>>> (rand2.rand *
>>>>> ) = 'ST_LineString'
>>>>> AND oid = 5030 /* Enter your own OID here */
>>>>> limit 100
>>>>>> -----Original Message-----
>>>>>> From: postgis-users-bounces at postgis.refractions.net
>>>>>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>>>>>> Behalf Of Martin Davis
>>>>>> Sent: Thursday, May 06, 2010 8:56 AM
>>>>>> To: John Abraham; postgis-users at postgis.refractions.net; Martin
>>>>>> Davis
>>>>>> Subject: Re: [postgis-users] Dot Density idea
>>>>>> I was thinking the same thing!
>>>>>> strk wrote:
>>>>>>> ST_RandomPoinsOnSurface(geometry, numpoints) would be an
>>>>>>> interesting
>>>>>>> function indeed. Sounds like a good job for GEOS/JTS.
>>>>>>> --strk;
>>>>>>> On Mon, May 03, 2010 at 10:49:32PM -0600, John Abraham wrote:
>>>>>>>> One of the things I miss about using ESRI's GIS is the
>>>>>> ability to do
>>>>>>>> dot-density maps.  Within a polygon, the number of dots is
>>>>>> proportional to a value, and the dots are randomly placed.  I
>>>>>> find it useful to be able to present several data values at
>>>>>> once (e.g. blue dots for population, red dots for employment).
>>>>>>>> I also find that it is a more intuitive way of scaling for
>>>>>> zone size
>>>>>>>> than dividing the value by the area of the zone.  That is,
>>>>>> the count
>>>>>>>> of the dots represents the actual number, but the density
>>>>>> of the dots
>>>>>>>> represents the density of the number.  So I don't have to decide
>>>>>>>> whether to divide the value by the area of the polygon to plot
>>>>>>>> density: both the absolute number and the density are
>>>>>> easily visible.
>>>>>>>> Since my open-source GIS viewing systems (mostly QGIS and
>>>>>> Mapserver)
>>>>>>>> won't plot dot-density, I've done without.
>>>>>>>> But today I realized that I can build these on the server
>>>>>> instead.  I
>>>>>>>> can generate random points within the bounding-box of the polygon,
>>>>>>>> throwing out those that aren't contained within the polygon,
>>>>>>>> repeating until I have enough.  Then I can save these points as a
>>>>>>>> separate layer, and display this layer using almost any desktop or
>>>>>>>> web based viewer!
>>>>>>>> Has anyone done this?  Can I do it in SQL or do I need to write
>>>>>>>> something in PL/pgsql?
>>>>>>>> John Abraham
>>>>>>>> PS I just bought the Postgis In Action book; enjoying it so far.
>>>>>>>> _______________________________________________
>>>>>>>> postgis-users mailing list postgis-users at postgis.refractions.net
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>> Martin Davis
>>>>>> Senior Technical Architect
>>>>>> Refractions Research, Inc.
>>>>>> (250) 383-3022
>>> Martin Davis
>>> (250) 383-3022
Martin Davis
(250) 383-3022
