[postgis-users] Dot Density idea
Jan Hartmann j.l.h.hartmann at uva.nl
Sat May 8 06:30:33 PDT 2010
How about this site?
http://www.johndcook.com/blog/2009/03/16/quasi-random-sequences-in-art-and-integration/
Jan
On 05/07/10 03:59, Ben Madin wrote:
> Martin,
> Assuming you wanted feedback - from an epidemiologists perspective, I like the first one - Complete Spatial Randomness is an important concept to avoid engendering a perception of order or clustering, and I'm thinking as long as the relative 'dot-density' is correct for each polygon, the CSR approach is less like to lead people to think the dots are located on significant points - in the context of obscuring actual locations etc this is important.
> If you want it more regular, then maybe you don't need to randomise it - or maybe this just means the function needs a user parameter to be able to set the level of randomisation - From 0 (completely ordered) to 1 (completely Random) (... to 2.5 completely clustered?)
> Just my thoughts - also for my money, I wouldn't change dot sizes. very confusing.
> cheers
> Ben
> On 07/05/2010, at 6:11 , Martin Davis wrote:
>> Check out this blog post for some images of different kinds of random point fields:
>> http://lin-ear-th-inking.blogspot.com/2010/05/more-random-points-in-jts.html
>> Martin Davis wrote:
>>> Sounds like it could work - with maybe a bit of fiddling to deal with cases where the grid cells overlapped the polygon only slightly?
>>> Random perturbation by cell radius can still result in some points being very close together.  (And I think this would also be an issue where only a small part of each grid cell overlapped the polygon).  This may or may not be desirable.  Perhaps a further check could be made to reduce the radius for points where this occurs.   Or maybe some sort of simulated annealing process could be use to push the points into a more even distribution.
>>> M
>>> Paul Ramsey wrote:
>>>> Even-yet-random :) nice requirement. How about just starting with a
>>>> regular grid and then perturbing the elements randomly with a radius
>>>> of a cell size? You can use the area of the polygon and number of
>>>> needed points to calculate the appropriate cell size and go from
>>>> there.
>>>> P
>>>> On Thu, May 6, 2010 at 10:28 AM, Martin Davis<mbdavis at refractions.net>  wrote:
>>>>> Good point about the need for even distribution of the points. That seems
>>>>> like a whole lot harder to code than simply randomly placing points in a
>>>>> polygon.  Does anyone have any pointers to algorithms for producing this
>>>>> effect?
>>>>> George Silva wrote:
>>>>>> The really big problem with dot density is that dots can overlap
>>>>>> themselves,
>>>>>> masking the real number, so if anything will be developed in this area,
>>>>>> the
>>>>>> points should be
>>>>>> A) evenly distributed
>>>>>> or
>>>>>> B) randomly distributed, but with some sort of "colision" tests, so there
>>>>>> is
>>>>>> no or little overlap.
>>>>>> This is a interesting idea, especially if we could make a materialized
>>>>>> view
>>>>>> with those points, which could be added to GIS software for presentation.
>>>>>> George
>>>>>> On Thu, May 6, 2010 at 1:53 PM, Sufficool, Stanley<
>>>>>> ssufficool at rov.sbcounty.gov>  wrote:
>>>>>>> Looks nasty, but it might work:
>>>>>>> select
>>>>>>> st_line_interpolate_point(
>>>>>>>       st_intersection(
>>>>>>>               the_geom,
>>>>>>>               st_makeline(
>>>>>>>                       st_pointn(st_exteriorring(the_geom), (rand1.rand *
>>>>>>> st_npoints(st_exteriorring(the_geom)))::int),
>>>>>>>                       st_pointn(st_exteriorring(the_geom), (rand2.rand *
>>>>>>>       ,rand3.rand
>>>>>>> from insert_your_table_name_here,
>>>>>>> (select random() as rand, generate_series(1,1000) as point_number) as
>>>>>>> rand1
>>>>>>> JOIN (select random() as rand, generate_series(1,1000) as point_number)
>>>>>>> as
>>>>>>> rand2
>>>>>>>       ON rand1.point_number = rand2.point_number
>>>>>>> as
>>>>>>> rand3
>>>>>>>       ON rand2.point_number = rand3.point_number
>>>>>>> WHERE st_geometrytype(
>>>>>>>       st_intersection(
>>>>>>>               the_geom,
>>>>>>>               st_makeline(
>>>>>>> ) = 'ST_LineString'
>>>>>>> AND oid = 5030 /* Enter your own OID here */
>>>>>>> limit 100
>>>>>>>> -----Original Message-----
>>>>>>>> From: postgis-users-bounces at postgis.refractions.net
>>>>>>>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>>>>>>>> Behalf Of Martin Davis
>>>>>>>> Sent: Thursday, May 06, 2010 8:56 AM
>>>>>>>> To: John Abraham; postgis-users at postgis.refractions.net; Martin Davis
>>>>>>>> Subject: Re: [postgis-users] Dot Density idea
>>>>>>>> I was thinking the same thing!
>>>>>>>> strk wrote:
>>>>>>>>> ST_RandomPoinsOnSurface(geometry, numpoints) would be an interesting
>>>>>>>>> function indeed. Sounds like a good job for GEOS/JTS.
>>>>>>>>> --strk;
>>>>>>>>> On Mon, May 03, 2010 at 10:49:32PM -0600, John Abraham wrote:
>>>>>>>>>> One of the things I miss about using ESRI's GIS is the
>>>>>>>> ability to do
>>>>>>>>>> dot-density maps.  Within a polygon, the number of dots is
>>>>>>>> proportional to a value, and the dots are randomly placed.  I
>>>>>>>> find it useful to be able to present several data values at
>>>>>>>> once (e.g. blue dots for population, red dots for employment).
>>>>>>>>>> I also find that it is a more intuitive way of scaling for
>>>>>>>> zone size
>>>>>>>>>> than dividing the value by the area of the zone.  That is,
>>>>>>>> the count
>>>>>>>>>> of the dots represents the actual number, but the density
>>>>>>>> of the dots
>>>>>>>>>> represents the density of the number.  So I don't have to decide
>>>>>>>>>> whether to divide the value by the area of the polygon to plot
>>>>>>>>>> density: both the absolute number and the density are
>>>>>>>> easily visible.
>>>>>>>>>> Since my open-source GIS viewing systems (mostly QGIS and
>>>>>>>> Mapserver)
>>>>>>>>>> won't plot dot-density, I've done without.
>>>>>>>>>> But today I realized that I can build these on the server
>>>>>>>> instead.  I
>>>>>>>>>> can generate random points within the bounding-box of the polygon,
>>>>>>>>>> throwing out those that aren't contained within the polygon,
>>>>>>>>>> repeating until I have enough.  Then I can save these points as a
>>>>>>>>>> separate layer, and display this layer using almost any desktop or
>>>>>>>>>> web based viewer!
>>>>>>>>>> Has anyone done this?  Can I do it in SQL or do I need to write
>>>>>>>>>> something in PL/pgsql?
>>>>>>>>>> John Abraham
>>>>>>>>>> PS I just bought the Postgis In Action book; enjoying it so far.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> postgis-users mailing list postgis-users at postgis.refractions.net
>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>>>> Martin Davis
>>>>>>>> Senior Technical Architect
>>>>>>>> Refractions Research, Inc.
>>>>>>>> (250) 383-3022
>>>>> Martin Davis
>>>>> (250) 383-3022
>> Martin Davis
>> (250) 383-3022
