[postgis-users] Extract points from multipoint geometries
Maxime van Noppen maxime at altribe.org
Mon May 10 08:47:23 PDT 2010
On 05/10/2010 05:32 PM, Charles Galpin wrote:
> I searched the archives and saw this asked in 2005 but it didn't appear to have a resolution then.  I have two points in a multipoint geometry which represent the start and end point of road segments that I need to extract the points back out of, but ST_PointN doesn't work for multipoints, nor can I convert the multipoint to a linestring with ST_MakeLine and use ST_PointN then on the resultant line (because it doesn't work on multipoint geometries either).
> Does anyone know a way to do this?
You can use the ST_Dump function.
http://postgis.refractions.net/docs/ST_Dump.html
Maxime
