[postgis-users] Cannot install postgis 1.5.1 on Postgres 9.0 beta1
Paragon Corporation lr at pcorp.us
Tue May 11 18:28:46 PDT 2010
Joel,
Which OS are you building under?  We tried under Windows and had other
issues, but assumed it was just a windows mingW issue.
Last we tried compiling at the 8.5lahpa something or other, we were able to
compile and install as I recall.  That was a while ago though.
Thanks,
Leo and Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Joel
Pearson
Sent: Tuesday, May 11, 2010 9:14 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Cannot install postgis 1.5.1 on Postgres 9.0 beta1
Postgis 1.5.1 compiles ok on Postgres 9.0 beta1, but when I run make install
it fails:
PostGIS was built successfully. Ready to install.
make -C postgis install
make[1]: Entering directory `/home/japearson/postgis/postgis-1.5.1/postgis'
Makefile.pgxs:17: warning: overriding commands for target `install'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:100: warning: ignoring old
Makefile.pgxs:63: warning: overriding commands for target `installdirs'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:148: warning: ignoring old
Makefile.pgxs:82: warning: overriding commands for target `uninstall'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:172: warning: ignoring old
/bin/mkdir -p '/usr/pgsql-9.0/lib'
'/usr/pgsql-9.0/share/contrib/postgis-1.5'
make[1]: /usr/pgsql-9.0/share/contrib/postgis-1.5: Command not found
make[1]: *** [installdirs] Error 127
make[1]: Leaving directory `/home/japearson/postgis/postgis-1.5.1/postgis'
make: *** [postgis-install] Error 2
Any ideas?  Is postgis simply incompatible with Postgres 9.0beta at the
moment?
Cheers,
-Joel
Joel Pearson
Software Engineer
Agile Digital Engineering Pty Ltd
A.B.N. 98 106 361 273
A: 5/28 Eyre St Kingston ACT 2604
P: +61 1300-858-277
F: +61 1300-858-477
M: +61 (0) 405-417-843
E: joel.pearson at agiledigital.com.au
W: http://www.agiledigital.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100511/159486d9/attachment.html>
