[postgis-users] Cannot install postgis 1.5.1 on Postgres 9.0 beta1
Paul Ramsey pramsey at opengeo.org
Tue May 11 21:32:19 PDT 2010
No, seems to compile and install perfectly fine under OS/X.
Two regression failures (*sigh*) due to a slight change in output from
SQL (select queries that don't return rows now return 'SELECT <number
of rows>' instead of just 'SELECT')
P.
On Tue, May 11, 2010 at 6:13 PM, Joel Pearson
<japearson at agiledigital.com.au> wrote:
> Hi,
> Postgis 1.5.1 compiles ok on Postgres 9.0 beta1, but when I run make install
> it fails:
> PostGIS was built successfully. Ready to install.
> make -C postgis install
> make[1]: Entering directory `/home/japearson/postgis/postgis-1.5.1/postgis'
> Makefile.pgxs:17: warning: overriding commands for target `install'
> /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:100: warning: ignoring old
> Makefile.pgxs:63: warning: overriding commands for target `installdirs'
> /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:148: warning: ignoring old
> Makefile.pgxs:82: warning: overriding commands for target `uninstall'
> /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:172: warning: ignoring old
> /bin/mkdir -p '/usr/pgsql-9.0/lib'
> '/usr/pgsql-9.0/share/contrib/postgis-1.5'
> make[1]: /usr/pgsql-9.0/share/contrib/postgis-1.5: Command not found
> make[1]: *** [installdirs] Error 127
> make[1]: Leaving directory `/home/japearson/postgis/postgis-1.5.1/postgis'
> make: *** [postgis-install] Error 2
> Any ideas?  Is postgis simply incompatible with Postgres 9.0beta at the
> moment?
> Cheers,
> -Joel
> Joel Pearson
> Software Engineer
> Agile Digital Engineering Pty Ltd
> A.B.N. 98 106 361 273
> A: 5/28 Eyre St Kingston ACT 2604
> P: +61 1300-858-277
> F: +61 1300-858-477
> M: +61 (0) 405-417-843
> E: joel.pearson at agiledigital.com.au
> W: http://www.agiledigital.com.au
> postgis-users mailing list
