[postgis-users] Bug or Problem with st_transform
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue May 18 06:55:24 PDT 2010
Stephen Woodbridge wrote:
> Hi guys,
> This is looking like it might be a bug on version "POSTGIS="1.3.3"
> GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS" which
> I know is ancient, but upgrading is not trivial.
> What I am trying to do is construct a shape in 900913 in meters and then
> rotate, transform it to 4326 and translate it to a location.
> The problem is the transform does not look correct. To just rough out
> the math, 4030 meters should be about 0.036202 degrees based on
> 4030/40075016*360 = 0.036202 but st_transform is giving back numbers
> like -5.67596869587729e-09
> Is this a known problem on this version?
> Is my logic faulty?
> Is there a better way to do this?
> Thanks,
>   -Steve
Hi Steve,
The first thing I would suggest is that you run the same query on a
spare fresh 1.4/1.5 installation and see what happens. The
transformation code had a good tidy up and some logic corrections within
that timeframe, including better reporting of error messages.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
