[postgis-users] how to use quartum gis to load postgis two tables with join operation, one is with geometry columns, another not.
George Silva georger.silva at gmail.com
Tue May 18 16:19:55 PDT 2010
Build a view with that query. Register the geometry in geometry_columns
table and you're set. But remov that AsText, otherwise you wont have a
geometry column.
George
On Tue, May 18, 2010 at 3:07 PM, sunpeng <bluevaley at gmail.com> wrote:
> hi, now,i know how to use quartum gis to load a postgres table with gemetry
> columns: the table is like:
> CREATE TABLE pois
>    uid integer not null,
>    name VARCHAR(128),
>    catcode VARCHAR(32)  not null,
>    catname VARCHAR(32),
>    others VARCHAR(32)
> WITH (
>   OIDS = FALSE
> SELECT AddGeometryColumn('pois', 'location', 4214, 'POINT', 2);
> now ,i have another table:
> create table DM_POIS_CLUSTER (
>    UID                  INTEGER                 not null,
>    CLUSTER_ID_0         INTEGER                 null,
>    constraint PK_DM_POIS primary key (UID),
>    constraint FK_DM_POIS foreign key (UID) references POIS (UID)
> then ,how to load the following sql result into quartum gis?
> SELECT ST_AsText(ST_ConvexHull(ST_Collect(location))) from
> pois,DM_POIS_CLUSTER goup by CLUSTER_ID_0 ;
> it seems qgis only load a table with geometry column.
> thanks a million!
> sun peng
> postgis-users mailing list
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100518/8eb7dc90/attachment.html>
