[postgis-users] Split Multistring on the_geom
Bolivar bdgt86 at gmail.com
Wed May 19 08:50:20 PDT 2010
Sorry, I didn't explain myself very well, now I can:
I don't need in every vertex a point or a node.  I want to rebuild my
geometry by adding new nodes where I need.
This is the logic that I want in pgsql code:
1. Read over all the multilinestrings that I have, all the_geom in this
case,(Is really neccesary to explode them into linestrings?)
2. By default the first point will be the start node, and i will store it in
position[1], when I stop in a vertex, ask to postgis If there's an
intersection, if there`s one, store it in position[2], if there's an actual
node (will be the end node), store it, and close the multilinestring.
3. Repeat that process on the next node.
Thank you Nicolas.
View this message in context: http://old.nabble.com/Split-Multistring-on-the_geom-tp28597888p28610253.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
